Time is flying and life keeps getting in the way... but a few bits and bobs have been done.
I got the auto chain slingers (on-spots) working, had a little play in the snow with them. Will probably pull them off though, once we're on super singles they'll need moving anyway and I am probably better to just carry chains. I don't intend on doing too much mid-winter highway driving!
Thanks
@Geo.Lander for the tip on the floor rust, I found some! There's a stupid carboard spacing thing behind the rubber trim which holds moisture and rubs on the paint, with dirt collecting as well, it is a recipe for corrosion. Luckily it seems to be just surface, I will clean it up, paint it, and keep it clean.
With the park brake engaged (which applies pressure to the front brakes, and take it away from the rear spring brakes), the front brakes would often leak air. Sat at 8bar for 30 years plugged into compressed air in Europe has probably loosened things up a bit! So I pulled them apart, cleaned them up and put them back together. Nice and clean inside. Not sure what the torque spec on the clamp bolt should be - where do people find that info? Is that what the WIS I keep hearing about is?
Cleaned up the big balls while I was there, thin coat of fluid film, grease in the kingpin bearings, she's good to go. I will check inside the balls soon, is that supposed to be moly grease in there, or just heaps of the usual kind of stuff?
Where do people go for a list of things to service and how often? I've found things on the LN2 forum but being in German a lot of it is hard to decipher. With parts hard to get, the more I can prevent failure the happier I will be. Especially since this is such a tidy unit, I will only have myself to blame.
I did some digging into the flame start system, seems like the plug had failed which had gone dead short and the control module fried itself too. The relay was burnt closed and a trace had evaporated. I've patched it up and ordered a new glowplug, and also a newer style control module. Hopefully get that all going to help with the Canadian winter starting. Until I get the box built and sort out diesel burning water heating systems.
Looking more at the service box on the back, I realised that it is built on a somewhat torsion free subframe. There is a steel tube on top of the frame, with brackets sitting out holding two long aluminium C channels. The front is bolted, then all others are on a slipping bushed joint. Pictures aren't overly clear. I maaayyyy re-use this for my habitation box, as I want to re-use the storage boxes anyway. But as mentioned before, I would like 18ft of living space when right now the box is 15ft. So it may still be possible, but I will have to do some more tearing apart before I decide.
My only semi-major issue I have found with this truck is the rear axle is crabbing hard. The passenger side of the axle tube is a 3/4" further back than the drivers side. You can see it on the military axle wraps that the passenger one (second image) appears to have slipped. I can only assume the spring pack centre bolt is sheared. I'll have to pull the whole lot apart to find out, which is a job for another day. Probably once the box is off the back and I'm about to cut the frame for extending. Or maybe if/when I fit the parabolic springs I hear such good things about.
Starting to pull the dash apart now, remove the high voltage driving unit for the blue lights, pull out the "RAG" black box monitoring system, basically try and simplify the wiring before I build it back up again with radios and VHF radios and backup cameras etc. I did find a 24-12V adapter hidden up above the sun visors, one less thing to buy and install!
I've failed to get the loudhailer on the roof working (Hella RTK 3), which is a shame. But not worth any more of my time as much fun as that would have been!
I had a play with the Rotzler hydraulic winch, I really should probably remove it since it is heavily overkill but it is just so cool it might have to stay despite the weight penalty.
So just bits and bobs for now. I need to start carving out more time to get things really going. I'm tempted to try and sell the whole service body as a unit, there must be a market for something like that with the PTO generator, but we'll see if I can find it.
