datrupr
"Back opnt he saddle"
Dude.............Have another cup of coffee! :Wow1::wings::bike_rider:
REX
LOL. There, I fixed it.
REX
I have a 1980 CM400T. It is a sorta-kinda cruiser styled bike. My friend in high school had a Honda "Hawk" I think it was a CB400. In my limited research, the Hawk has a fuel capacity of 3.8 gal. Mine has a capacity of only 2.6 gallons.
Does anyone know if the Hawk tank would fit on my bike? Any Idea where I might find one to try?
REX
Next time you hit a corner too hot, look ahead to where you want to go through the turn and counter steer.
Breaks aren't a good idea once you're leaned over.
You'll be amazed how far you can lean over w/o going down.
Helmets are a "one time use" item. If it bounced -- it should be replaced.
In the real world, most do not follow that rule. Each rider must answer one question for themselves: How much is your head worth? Are you willing to risk your life on a helmet which is known to be damaged? The choice is yours.
If you need to shed some speed in a corner (ideally, you would be at the correct speed *before* the corner), the rear brake is much more forgiving than the front. Obviously, you don't want to lock the rear tire up, but gentle application can slow you down without the huge nose dive and steering issues associated with the front brake.
As I was sliding off the bike saddle on the inside going around a corner my foot clipped the rear brake pedal. The bike Instantly stood up straight.
The traction circle concept is a good thing to understand, regardless of how many tires a vehicle has. I don't recall it being in the MSF course (of course, it's been years . . . ), but it probably should be.I don't know if the Traction Circle was discussed in your class or if you're familiar with it or not.
ABS is your friend :roost:
I got my motorcycle back this afternoon. :bike_rider: Unfortunately, it was right in the middle of evening traffic time. I hadn't ridden in a few weeks so I took it easy and took the back ways home. No incidents to report. The windshield was broken in the accident and I am eager to replace it. It gets very windy at 65mph! :Wow1:
REX
