Now that I figured out how to upload the photographs I might as well tell you a little about the truck
LandCruiser 100 series Turbo Diesel Automatic
ARB bar with Warn 12000lbs winch Driving lights and spot lights with seed protector net
Safari snorkel with modified air intake
Unichip power up module 175Kw 550Nm
ARB air lockers front and rear with modified activation to allow selectable activation of front or rear independently. Lights wired to original diff lock lights in dashboard
Pin 7 mod on centre diff lock to allow diff lock activation/deactivation in high or low range
Triple battery system with inverter
Roof rack with roof top tent 2 x 20 lt water and 2 x 20lt diesel cans second spare wheel with Cooper STT 285/70 16 tyre and exhaust jack
Tyre pressure monitoring system 2 x Garmin GPS's UHF Radio
2" raised suspension with heavy duty torsion bars at front and extra heavy springs in rear
Side steps / rock rails mounted at four points on chassis
Engel fridge running off third battery with inverter
145 lt diesel fuel in two tanks (sub and main)
Rear mounted 10000lbs Warbn winch
Normal recovery equipment and spares
EEZITYRE spare air
lots of other little extras to make remote travel comfortable
