Latest Photo?
Having some fun at Disney, OK.
Recent trip with friends new to offroading in Hungry Valley SVRA, Gorman, Ca. (And letting my 11 y/o son drive the cruiser... He was smiles from ear2ear and my wife scared ********-less!!!
Dogs like wheelin too!
The all Toyota Pack!
My '97 in front with the '69 trailer carrying Christmas trees and my buddy's which was recently purchased from an expo member. As for the mudflaps-my dad had them squirreled away in the garage.
Nice!
what is your rear bumper setup?
It's a custom bumper the PO whipped up bolted to a shortened rear frame. Just about flush with the rear hatch of the LX but very weak in the corners. If you look closely you can see that its broken on the drivers side corner :) Will be replaced with a dual swing out from 4x4labs shortly.
Now that I figured out how to upload the photographs I might as well tell you a little about the truck
LandCruiser 100 series Turbo Diesel Automatic
ARB bar with Warn 12000lbs winch Driving lights and spot lights with seed protector net
Safari snorkel with modified air intake
Unichip power up module 175Kw 550Nm
ARB air lockers front and rear with modified activation to allow selectable activation of front or rear independently. Lights wired to original diff lock lights in dashboard
Pin 7 mod on centre diff lock to allow diff lock activation/deactivation in high or low range
Triple battery system with inverter
Roof rack with roof top tent 2 x 20 lt water and 2 x 20lt diesel cans second spare wheel with Cooper STT 285/70 16 tyre and exhaust jack
Tyre pressure monitoring system 2 x Garmin GPS's UHF Radio
2" raised suspension with heavy duty torsion bars at front and extra heavy springs in rear
Side steps / rock rails mounted at four points on chassis
Engel fridge running off third battery with inverter
145 lt diesel fuel in two tanks (sub and main)
Rear mounted 10000lbs Warbn winch
Normal recovery equipment and spares
EEZITYRE spare air
lots of other little extras to make remote travel comfortable
The rear winch is a Warn 10 000lb low mount winch. It is mounted in a custom cradle, which uses the Hayman Reese tow hitch mount to slide into. There is a dedicated quick couple electrical connector which runs of the auxilary battery.
Sometimes it is easier to winch yourself out the way you went in, rather than trying to winch yourself further into trouble. The Winch and cradle is removable so that it does not affect the rear departure angle. I also use it when I have the jet ski trailer hooked up as it makes it easy to recover the jetskis onto the trailer and i can then drive straight off.
If you have ever tried to use a front mounted winch to winch backwards, you will appreciate the ease of a rear mounted winch.
I will post some photographs up next time I take the truck out for a drive.
Merry Christmas to all and I wish you all safe travels over the festive period
Deputy Dan
