110, how bad really?
Although perhaps a bit late, here are my thoughts on owning a 110 - 300 Tdi Hard Top.
It all comes down to maintenance, expectations and history.
- maintenance. You're getting a 30 years old vehicle and it will show. Unless you buy a totally 100 % rebuild vehicle – very serious money – you will get a project. Either small, or big. Chassis rot, bulkheads rot, metal and aluminium have a nasty reaction to each other and the electrics….
But, it is all very basic. 300 Tdi engine require fuel and will even run without electricity (don’t ask me how I know) and although they are not the strongest of engines, they usu. will get you home.
The green 110 in the picture is a vehicle I created for serious long distance Overlanding and it never failed me. Things went wrong, broke and all that but I always got home. It is a spartan vehicle and nothing you can do will change that. One can improve comfort, reduce noise etc. but in the end it is a box on wheels and designed to work for a living and hosed out.
I took mine on long trips – 6,000 – 12,000 miles at times – and I have learned to drive, live & sleep with them. But they are not for everybody. Headsets get old to have a conversation with your passenger, listen to music without turning the volume way up and elbow space is restricted. Speed is relative, towing a trailer takes planning and sleeping in them is when you’re 1.85 (6ft. something) a challenge.
The cage is something I really suggest to consider – if they roll there is not much protection and many people use them as a base for the rooftent. Also, please remember that the heater in this Defender is really a laugh.. I replaced mine with the biggest one I could possibly fit after seriously modifying the bulkhead and it worked very, very well…
So, eventually I accepted my age and sold it. Have “series III” left and changed to Discovery II’s that will basically do the same job but in greater comfort. Still can’t sleep inside really well but life is a compromise.
If you’re not afraid to work on your vehicle, deal with rust and are not in a hurry to get somewhere they are a fantastic machine that will try to keep going when most are about to give up.
Good luck making you mind up.
Unreliable ?
If you purchase a 30+ year old defender from Africa- a continent known for being brutal to vehicles, and also a place most vehicles only receive maint when they break, expecting to just start using it might be dissapointing. In my experience working on defenders daily, its usually less about regular maintenance, than committing to the larger undertaking correcting 35 or more years of deferrred maint. They are simple vehicles to work on and require few special tools.
We've done significant rust repair on African imports so any claim that "its rust free because its from Africa" are sales pitches, not reality.
Would a 60 series toyota thats run US highways instead of an African import thats seldom seen pavement make more sense ? If your asking these questions here you should buy the Toyota.
The worst thing you can do for reliability of a defender is let it sit unused.
Unreliable ?
Getting a good baseline is critical for getting reliability out of a vintage anything.
Service everything, brakes fuel system, cooling system, exhaust, wheel bearings/axles, steering, suspension, engine accessories/belt... its all unknown until you go thru it.
This is not a negative but a positive to me lol. I'm looking for a project build. I have brand new trucks in the garage and they are boring to me now, I'm dying to get my hands dirty again. As mentioned in my original post "My plan would be to go through the truck systematically and rebuild/refresh whatever’s needed to make it as reliable as possible". It will be nice to have a winter project, I was about to start tearing down the motorcycle and put it back together to cure my seemingly endless boredom. Winters are long and cold here in CO, and this will be the first winter in a while we aren't spending down in Baja. I think it will be quite fun to tear it apart and repair / replace as much as I can.
My uncle and his business partner bring 1-2 of these in every month. They have a nice 2000 TD5 110 that just came in that I am heading over to Baltimore the first week of Dec to check out, and hopefully trailer back home!
Unreliable ?
I won't be taking it on any long trips right off the freighter. Have a long list of maintenance and parts I will probably rebuild / replace when I get it. Luckily I havent seen too many with rust issues. Like you said its like 25+ years old at this point, SOME rust is inevitable.
A 60 would be nice. Maybe next year if I get wind up my ass to LS swap something.
Love hearing about a well traveled Defender!
Yes I have been prioritizing finding ones with a decent maintenance history. As long as the engine doesn't blow on my, I don't mind replacing most other parts, which I may do just for peace of mind.
The cage would be a great idea, I follow a couple on Instagram that had a roll over last year in theirs and it folded like paper. Unfortunately the plan is for a Alu-Cab roof conversion so I am not sure how I could incorporate a cage, but something else to look into!
We heavily looked into the Discos. Certainly a little nicer, but alas the Defender tugs at the heart strings.
Same
I love fiddley little projects like packing wheel bearings and the like. You feel like you're doing something but not the not fun kind of doing something like bench pressing a transmission.
Which I guess throwing a clutch in a new to you rig may not be a bad idea either though...
Disco market is weird, they are so all over the place on pricing and condition it is hard to get comfortable actually pulling the trigger.
Same
A LOF clutch is in the cart, one of the many things getting replaced right away since I won't know the condition of. Brakes, clutch, wheel bearings, swivel hugs, fluids of course, all bushings, all suspension, and I am sure I am missing 40 other things. I think my cart at NWR is over $20k lol
I'm in France - not a native English speaker so please be kind - and the situation here in Europe is a bit different from yours I guess. Brexit made parts quite a bit more expensive but you can get them. Biggest challenge is the quality of parts. Boxes means nothing - it is basically "cross your fingers and hope for the best"
You can have a cage and a lift up roof. I have seen several in the Alps on German vehicles. The hoops go up with the roof and slide back in when you lower the roof. Cages are, to be, a consumable. They have to work once and then you replace them. Otherwise one has to add a lot of steel to brase it - and that all takes up space.
Lift up roofs have been around LR's for as long as they axist in many different forms. Most are front windscreen hinged and give a lot of sleeping space. However, that roof while standing up also catch a lot of wind and I have seen many times people spending rough nights in the seats because the wind stopped them from sleeping "upstairs"
Because I'd prefered a rigid cage, and wanted to sleep inside, I took a different route :
Between the B and D hooop, a section of the roof was cut out and a hatch fitted. Went up horizontally with 4 gasstruts and provided seriously good standing height. Closed, it sat 5 mm. under the cage so fully protected.
They're not complicated vehicles. The 300 Tdi is a good, but wet, engine, electrics "basic". Weight is your enemy ! Keep it down. Also, everything in the vehicle makes noise so that is something that you need to look into..
If you ever want to go for an automatic conversion, the ZF mated to a Mazda 3500 SLTi gives you a totally mechanical setup and transforms the thing...
This one I converted to Mazda + ZF and is was just awesome.... In fact, it was so good it I was made an offer I just had to take. Still regret it.
Have fun and ask whatever you want.
Well, if you have an uncle moving some 50 defenders into the USA every year, he will know a lot about what to look for in a used one. I think with your skills (hand-wave a LS swap, experience w. older trucks, multiple other rigs, lots of time) you shouldn't worry especially, get one and have at it, life's short sell it if it doesn't work out.
For anyone not as connected, the actual time/money to have a solid 30 yr old Defender can offset the cool factor for travelers (vs. a collector or mechanic) I had a D90 and put 120,000+ miles on it, it was mostly reliable, easy to work, on but absolutely full of w t f 1980's quality/engineering and stranded me twice (thankfully in civilization)
My 110 is 36 years old this year. It was s/h and 5 years old when I got it, and was well maintained by a utility company. The first engine was 2.5TD which was ok but got tired at 125,000 so was replaced with a 200Tdi of unknown age but which has now done an additional 200,000 miles with me but had probably 50k miles on it at least when it was fitted so its been excellent. Oil changes every 4k miles helps as does all the other fluids being changed regularly.
This may be an odd take on this, but whilst the comments above about the issues caused by steel/aluminium construction are real, that same construction allows easy repair by even the most cackhanded of mechanics! Where I live with winter salted roads and lots of rain, back doors last 10 years, easily replaced. Front doors 10-15 years before needing some TLC with repair parts and replaced at 25 years if you're lucky. The 'boxy' construction allows for flat sheet repairs whether pop-riveted on (for alloy) or spot welded (for steel). The lack of curves in many of the vulnerable places makes for easy fixing and, in my case, adaptation.
Over the years I've changed lots of parts, and added bits that seemed practical. The biggest is the lifting roof, made on the drive with minimal tools, and sporting a fabric sided roof tent. This was ok but cold in winter and noisy on windy nights. So after some consideration I added insulated hard sides and electric lifting. This is more comfortable. Because of the flat sides and proper corners (rather than lots of curves as on some other contenders) it was relatively easy to make things without access to specialist tools, and aluminium is light and easy to toss on and off by hand in the process.
So this is a 36 years ol 110, lifting roof, water tanks in the wings, extra fuel in rear wing, interior sink, fridge, sleeping for three adults and a child at a pinch (child is small bed across front seats, two adults 'upstairs' and one below) and bowls alone nicely at 55mph all day, with enough power from the old engine to get near to 70mph if you want to.
Its needed. all the usual repairs, stuff dissolves and wears out but I can access a lot of it by laying on the ground underneath and there are loads of mechanics about with vast experience of these vehicles so unusual issues are often easily resolved. Would I buy it again? Yes, I had a 4x4 Subaru before this and the first exhaust I had to replace almost bankrupted me!
Good luck with yours!
5mouse
