Pop-up Flatbed Camper?
Carl2500
Hello all!
Finally the stars have all aligned to where I've got the freedom and money to build my truck into an expedition rig, and drive up through Alaska! This has been a lifelong dream of mine.
I'd like to leave this May if all works out well.
I'm looking for a used flatbed pop-up camper that is rated for cold weather.
Could anyone help me find one? I'd like to get it within the month so I can start working on it, and the truck.
Carl
brianjwilson
Some sort of lost...
There isn't much (anything?) Off the shelf like that. If it has to be used, you could modify a standard pop up camper by adding storage or something.
However all Terrain campers recently built a custom flatbed popup for the owner of wanderthewest.com
Coyote RV (phoenix campers) builds custom campers all the time, and has posted about some pretty impressive turn around times. They would be one of my first phone calls.
Overland Hadley
on a journey
Camper in the next month near Michigan? I would say your best bet is going to be to buy a normal camper and add storage along the sides to make it ''fit'' your flatbed.
What vehicle are you working with? If you have a full size there will be more used options here in the midwest, if you have a Tacoma sized truck a used camper is going to be hard to find unless you are willing to drive to west coast.
And congratulations on the stars aligning for you, always good when things come together.
Carl2500
Thanks for the responses.
That thread from Carlyle is a great one, still picking through it.
I don't see many designed for a flatbed, let alone a pop-up style. I think I'll do what you guys suggested, and start with a normal pop-up truck camper, and mount outside storage boxes to fill in the space. Are they all about the same width on the bottom? I'd prefer as wide as I can get.
NothingClever
These toolboxes (link below) should fit pretty well under a standard pop-up. The two lengths (48" and 72") will fit even a small Toyota pickup (all bed lengths) so you should be good for a longer flatbed, too. The height is only 16" so you shouldn't run into interference there, either. The one area where you might lose is the box depth...it's only 12" so you could end up with 'dead space' behind the box (unless you cut out the back of the box).
http://www.protech.net
Pretty spendy but they're tough boxes. If you know somebody with a brake, you could fab up some simpler but fully functional boxes for less.
docdave
Aspiring overlander
you might have a bit of extra space between the top of the cab and the cabover....maybe an innertube or other spacer?
Carl2500
I'd like to be able to take my street legal dirt bike ('85 honda xr200r) along with me, I could probably use the extra 24" or so at the back for the bike. Would love to have a pass-through from cab/camper, as this trucks only purpose is for the camper, but that'll probably be down the road if I do anything like that.
docdave
Aspiring overlander
A fold down gate at the back mounted to the bumper might be a way to go for the bike, how heavy is it? Lots of campers have a sliding window and a boot from the cab to camper, maybe that would work for the pass though. Otherwise, the front of the camper would require considerable remodling for a walk through......Have you thought of an "interim" camper to try out some concepts, and solidify your design for a custom built unit?
NothingClever
Visual learner here. You mean a short pop-up which leaves you with 24" of bed space at the rear, correct? That's not a bad idea but I agree with docdave....go for a camper that fits the length of your bed (provided your truck can haul the weight) so you're as comfortable as possible in the camper after a tough day of riding. Use a hitch-mounted moto-hauler to carry the bike. The XR200R can't be all that heavy. What's the tongue weight rating on your hitch?
Also, if you're dead set on the short camper in a longer bed, you'll still be able to run the toolboxes along the side if you install a flatbed.
Hopefully we're making sense to you. I think you're onto something slick which will open up a whole new chapter of riding. Have fun!
Carl2500
The bike weighs in at about 250lbs.
If I went through with the pass-through idea someday, I would like to remove the center seat/console, remove the middle portion of the rear sliding window, Cut and re-enforce the sheetmetal of the backside of the cab, from the bottom of the window to the floor, and make appropriate modifications to camper.
If the camper was off I could seal it up with some plexiglass and door seals. But I'm getting ahead of myself here, this is why this projects gotta be down the road :D
Yeah lately I've been warming up to the idea of buying a cheaper camper to get some experience, see what I need, and what I don't. I'll probably go that route, cause at this rate my designs of a custom rig will take forever to turn into reality, lol.
Musta been tire when I wrote that last reply, I was thinking of my 10' flatbed, vs. 8' bed, but I forgot lots of the campers hang out a couple feet anyway, so it'll probably just be flush with the rear bumper. Which leaves me with the motorcycle mount using the receiver hitch idea. Tongue weight rating of about 500lbs.
Kilroy
If you have to move the MC to get into the camper you will hate it the first weekend. I'm sure storage is partly why DirtyDog had his door put on the side. If you leave it on the back, you need to have it far enough out to allow getting into the camper. If you have it sticking that far out there will be a lot of leveraged weight out there. I think the front is a better place for the MC. Contact Sean at GoAnywhere http://www.go-anywhere.us/products/versahaul.html for a handy MC hauler.
I believe you will have a more usable storage on the flat bed if you make up a custom enclose for an existing flatbed, vs storage boxes which are not going to fit exactly. I've just used the space on the flatbed with fold up side panels on the flatbed which contain my storage. Problem I have with doing it this way is everything has to be loaded/unloaded separate from the camper.
haven
Forum member DirtyDog worked with All Terrain Campers to create a popup camper for a flatbed Ford F250
Read about it here
http://www.expeditionportal.com/forum/threads/68424-My-new-custom-ATC-flatbed-camper
If you used a longer wheelbase truck, you could safely extend the flatbed a couple of feet beyond the end of the camper.
project13support
