expedition film trucks
expo80
Looks awesome Nat!
Two questions if I may:
Where/how are you installing the Yellowbox? I followed the writeup on the MUD homepage (http://www.ih8mud.com/product_reviews/fzj80-yellowbox.php) and installed mine behind the glovebox, but I suspect it is interfering with the cruise control holding a steady speed. I'd be interested to hear if you are doing something different.
What type of carpet and adhesive did you use inside the tailgate? It looks great.
Cheers!
Im installing the yellow box the same place, same way never had an issue with the cruise control using that write up tho.
I used 3M's super 77 spray good stuff it holds well but if the carpet ever gets nasty and need to be replaced it will still peel off with out damaging the dyna-mat
The carped is actually replacement car carpet from wall-mart:victory: cheep and durable
cheers, nat
expo80
A Resurrection if i may!
Between moving to upstate NY and work life has been a little crazy lately so i haven't been posting much so I thought i do a little up date on this 80.
About a month ago I jumped in to the 80 to move it, problem was that it seemed hard to start and as soon as it started i got a nice big plum of antifreeze smelling smoke billowing out of the tail pipe...NICE head gasket time!
A week later i pulled the Engine and striped it to the block to find the fire ring on #6 cylinder head gasket deformed, go figure:rolleyes:
A quick call to the machine shop and the block, head, intakes, upper pan were place in the back of the other 80 and shipped out.
much more to come...
expo80
received ever thing back from the machine shop.
here is a list of the things that was done
washed and glass beaded:
valve cover, both upper and lower intake manifolds, timing chain cover, upper oil pan, throttle body, and head
glass beads were flowed threw both intake manifolds to make a smooth surface for better flow
intakes were also port matched for better flow
head:
ported and polished for better flow
cleaned
valve grind and seats
resurfaces .004
valves re adjusted
block spec if you care to know:)
rods
1 - .0018-.002
2 - .0018-.002
3 - .0018-.002
4 - .0018-.002
5 - .0018-.002
6 - .0018-.002
spec. .0013-.002
max .0039
side clearance .006-.007
spec .0063-.0103
max.0143
mains
1- .0025
2- .0025
3- .0025
4- .0025
5- .0025
6- .0025
7- .0025
spec. .0014-0021
max .0039
end play .004
spec. .0008-0087
max .0118
Amazing since it has 150k miles on it. when i redid my wifes engine it was very close to this except it had 230k on it. I just love Japanese engineering!
expo80
ENGINE ASSEMBLE TIME!
new chain, chain guides, gears inspected and cleaned
expo80
timing chain cover with new seal
new water pump
oil pump reassembled with cover using torque screws
expo80
valve cover (powder coated), spark plugs, oil filter, new oil cap, pcv valve and grommet, spark plug tube seals
expo80
Upper & lower oil pans, Rear main seal and oil cooler
expo80
sensor installed, new oil level sensor, crank sensor
expo80
lower intake, fuel rail with cleaned and balanced injectors, fuel filter. dip stick, water pipe, alternator, plug wires, cap& rotor, egr valve
