justcuz
Have you given any thought to using an older Willys wagon? Or possibly a 2 door Cherokee wide or standard track. If you are looking for a low center of gravity the 2 door Cherokee would make a very cool build. Newer Jeeps track width are probably close to a standard width Wagoneer/Cherokee track and you should be able to locate a cost effective Cherokee fairly easily.
With your skills you could easily open the wheelwells to accomodate 37" tires. Maybe narrow a set of 1 ton axles, lockers, 4 cyl Cummins, 5 spd trans, t-case of choice, set up your rear accomodations...done. No major fabrication needed.
