UJOR Build Thread
ujoint
Supporting Sponsor
Finally have some time to load some pics from the trip. First off, a big THANKS to Mickey Thompson Tires for having UJOR represent them at the Overland Expo. I hope we helped sell some rubber!! My friend Mike had his JK & Trailer in the booth too, super nice rig.
Here are 2 new rigs, one built here at UJOR, and the other in FL. BigBlack went home last week, a super clean (new) van with 6" lift up front, 8" out back. It has a stage 1 D60 with RSC and 35" Toyo MT's on some factory Ford wheels.
The other is this beast in FL! UJOR Stage 2 front axle w/RSC, 10" lift on 41's!
More pics/info coming soon on this rig.
wl1193
Hi Chris. Did you ever receive the glass fenders from Glassworks Unlimited? If so, how they did turn out? Keep up the great work!
ujoint
Supporting Sponsor
More pics & details----
05 E350 6.0, 6" lift on 35's, Aluminess F&R, UJOR rear skid system, Stage 2 front D60, Stage 2 Sterling rear, Bilstein 5100's, BFG AT KO's, 17" Pro Comp Steel Wheels, full engine upgrade (EGR cooler delete, turbo rebuild, FICM module, engine harness, coolant flush, EGT gauge, Scangauge monitor) AMP steps, 271 t-case with 1350 CV's F&R, drives like a dream!
ujoint
Supporting Sponsor
Yes sir you do! The RSC kit comes with a straight tie rod & I mounted the stabilizer, it's tight in there!
cowboy4x4
in your description, what did you mean by "engine harness" is that an upgrade of some type or did it just need replacing.
ujoint
Supporting Sponsor
It needed to be replaced. It's a problem on some early 6.0's, the harness wears down and starts to throw random codes. Usually for injectors. This one was so bad that you could move the harness with a pry bar and it would run rough. Hard to diagnose.
V45W_Proto2.5
