Overland XJs Unite!
Explorer 1
Explorer 1
let's make this easy...
Wow sounds like a lot of detailed lists.
So I guess I'll join in,........let's see how can I make this easy.
1990 XJ, Original front seats and steering wheel....oh yea and tail lights too......everything else has been replaced or modified.
Thanks,
Fred
Explorer 1
CAMartino
My 2000 XJ Daily Driver build up
Recent run to Broken Arrow
An older image prior to raising it 2.5". Bungies holding the sway bar up.
My current configuration is:
Rusty's 4.5" springs F/R.
6 deg wedges
2" Shackles and 2" spacers. RC Shackle Relocation Brackets to be installed.
SYE
Woods Shafts
Earls extended brake lines
RE Track bar
Short arm that was one the vehicle when I got it. Rancho?
Sliders I built
Misc other.....
I will be doing a long arm upgrade, gears, lockers, 33" tires, front bumper and tire carrier. I'm not in a hurry as the current setup gets me where I want to go pretty easily.
It is my daily driver so if I wreck it I'm screwed.
FordGuy1
What's up Rich?..... That is the nicest XJ I've ever seen.... You forgot to list the Lowrance unit.
Thanks! Just started lurking on this site, have been doing a lot of back country stuff, less rock crawling. Kim and I just ordered a Four Wheel Camper for the SuperDuty so we can do a lot more camping in all weather conditions.
xjamsoil
Thanks,
Fred
Explorer 1
Sounds good!
Mekcanix
Camper
92 XJ
roughly 4" of lift
33" mud terrains ( to be replaced with Duratracs this fall)
Milemarker winch with synthetic line
Dana 30 front with old style ARB tubes interior sleeved , 4.10 gears (going to 4.56) Ruff stuff diff cover
Ford 8.8 rear 4.10 31 spline, detroit locker.
custom bumpers with rear tire carrier
rock rails
running a bastard leaf pack in back consisting of XJ, rough country, and Ranger leafs, and teraflex shackles
front running Rubicon express drop brackets and Rough country old style arms (flex on threads)
Custom roof loading platform with flat halogen running lights
TJ rear flare all around with custom built spacers in front
and probably another dozen things i cant remember right now
a this is my daily driver as well
xjamsoil
You happen to have anymore pics of the platform. I've been looking around for a design but I have not come across any.
Mekcanix
Camper
I will try to take some this week
but its a real simple set up
1x1x.120 wall tube welded together with expanded metal on top
Mekcanix
Camper
here is a pic of the roof top platform/rack hope it helps
I am planning on building a better, cleaner version this winter
along with a better front bumper design
lil_freak_66
mudspace.com rep
just picked her up recently, havent even thrown on new tires yet.
1988 xj pioneer, 140K original on it, almost no rust.
currently on it...
Air Shocks
Emergency lighting(code 3 pse 6100, galls deluxe headlight flasher)
siren(galls controller, carson speaker)
was going to buy a small bds lift from buddy that included shocks for $150(3", he won it but already has a 4.5") and my radiator decided to crap out on a 110 degree record breaker a week or so ago, upgraded to a new csf 3 row aluminum radiator which im installing as soon as i post this.
plan to do skid plates, the lift, some decent a/t or m/t, snorkel,axle swap,bumpers/winch, sliders and electrical mods...not going to do extreme trails that demand body damage...i just like to minimize potential for breakage.
here it is a few days after picking up.(yes ive taken off the hideous side steps!)
cdn_xj
Nice job on the TJ flares.
Usually when people use TJ flares they rush the install and it doesn't wind up looking very good at all; but your install looks almost factory. The use of rear TJ flares on the front really helps too: you don't have double side marker lights. Well done!
TOI
Web Adventurer
i finally got my overland XJ on the road! shes ugly but she drives like a caddy
soon to be 4x4, lifted, and ready for fun
Mekcanix
Camper
thank you very much
chuber1994
Overland Newb
Ill join in
Here's mine:
5.5" Iron Rock Offroad Lift
33" Goodyear Kevlar Muds
15" Cragar Soft 8s
4.56 Gears
Upgraded Diff Covers
1-ton Chevy Steering
Protofab Front Bumper
TMAXX 10000# Wireless Winch
Spectre Cowl Cold Air Intake
Bushwacker Flat Flares
PIAA Fogs
Upgraded Headlight Wiring Harness & Autopal Housings
Rhino-lined Rocker Panels & Roof
Welded On Rock Sliders
Upgraded Power Acoustik Flip-out Head Unit and Kenwood Speakers
Husky Liner Floor Mats
Ignition Kill Switch
Removed Rear Sway Bar
Rough Country Sway Bar Discos
New Sway Bar Bushings
SYE and extended Driveshaft
Rhino-lined complete interior floor
LED Dome lights and Floor Lights
Hi-Lift Jack and a newer installed hitch
Roof Rack
New Headers and Exhaust
Removable Front Doors
Mostly Black Interior (Door Panels have not been converted yet)
Henrybrowne
