Alaskan Camper Build Up
chilliwak
Carl, if you call that roughing:Wow1:it, I will join you anytime..... I will even bring some beer:beer:!
Carlyle
Available in CO now, hoping to hit a few breweries on the way home in a couple days.
ashamberg
Carl:
I have followed your whole thread and have learned a great deal. Thank you. Any chance you might put a source list together for your second build like you did for the first one?
Aaron
chilliwak
Welcome to the site ashamberg/Aaron. You have good taste in vehicles showing interest in Carl's super cool truck. Thanks for keeping us updated Carl. We all love following your adventures. Cheers, Chilli....:)
Jr_Explorer
Carl... Time for a TCM update as a LOT has happened since the last one (you know... Like having the ultimate camper rig burn down, start over and build a better ultimate camper rig!).
Carlyle
Gordon and Angela are emailed and we shall see.
I'll update a few upgrades this week since we arrived back from Holidays in Oregon. I'll work on the master list for Aaron shortly, I know from other builds how that helps.
Next trip, anyone been over the Chuska range in NM? Looking at taking the alternate route from Canyon de Chelly to Chaco. I'm sure someone has found the really back route we are looking for. https://maps.google.com/maps/ms?msid=216896708914626560608.0004cbd13d185a328632a&msa=0 (Tentative mild route).
Next major mechanical step is finding air lockers for this truck, I heard "Just Differentials" may be making them but no response so far.
scottym
Carl
I happened upon your thread and have been following with much enthusiasm. I am in the planning stages of doing a similar build with the non cab over Alaskan on a flatbed mounted on a FUSO FG. I actually talked to the Bryon at ALK camper and once he got what I was going to do, sent me pictures of yours during construction.
I have a few (alot) of questions and hope sometime to ask you a few about specifics, but so as not to overload this, I hope you can answer just a few. First on your current build or your previous one, are/were there any issues mounting on a flatbed? Anything you have or would do differently?
Second, why did you put the rubber on the flatbed prior to the 2nd install?
I also would welcome the source list also.
Thank you
Scott (from Western Colorado)
General Automag
Picture this longer and on a F550...
I guess this type of vehicle never leaves pavement. 'Very nice though.
Stump Jumper
Carl,
What a dream to have built what you have!!!! Simply awesome. Three hours reading and I have got to the end....it's been a few months back but I have to ask, do you still have the old Rickson wheels and tires from the old build still for sale?
Thanks for all the hard work in putting this all down so we can see it instead of dreaming it.
Darin
Carlyle
Specs
Sorry for the delay, but I've been working in the brewery!
Here is a short list to start with though
April 2012 14.3 non-cabover Alaskan Camper with OEM add ons:
Double pane windows throughout
Extra one inch insulation on all exterior walls, floor and ceiling
45 gallon water tank
5 gallon grey water tank with quick disconnects
5 gallon Atwood hot water tank with electronic ignition (doesn't blow out in high winds)
Platinum Cat vented catalytic heater (The one and only)
2 x 225 amp hour Lifeline Agm batteries
Cow hide leather settee (Justlather.com)
Large pantry slide
Nova Kool 5.5 cu ft 12 volt fridge
Thetford cassette toilet
Two Carmanah 175 watt high efficiency solar panels
25 amp solar regulator with 2000 watt sine inverter
Coleman Mach 2 AC
LED Lights inside and out
Piaa back up lights
Wilson cell phone booster with internal and external antenna (solidsignal.com)
WiFi booster (Radiolabs.com)
Carefree of Colorado Awning
Truck:
2012 Dodge 5500 Laramie Edition Crewcab 197" WB
Chassis Cab
Rickson 20" custom wheels
Continental MPT-81 Tires Yaesu 7900r Ham with 5' Comet antenna
Viper alarm that extends to camper doors and windows
Yakima roof rack and gear loft on cab of truck
Aluminess custom bumper with Piaa driving and fog lights
Warn 16.5ti winch
Hard wired back up camera from Dodge
Revtek Front end leveling system
Custom flatbed with independent suspension to flex away from truck frame (Local Welder and Ute)
Aluminum storage boxes under bed (Jobox)
16.5 gallon propane tank with plumbing and disconnects to both sides outside
Yamaha 1000 watt generator converted to propane (US carburation)
Viair extreme air compressors with 2 five gallon tanks to run jack, air tools, air bags, air tools and transfer water
After purchase installs:
Pioneer DVD deck with Polk waterproof speakers
X 4
19 volt upverter for TV (Powerstream.com)
Wilson cell phone booster with internal & external antenna
32" back lit LED TV on glide and 12 volt linear actuator to lift from behind couch with remote (Firgelli.com)
Laguna table leg and custom table top
Petersmithinak
