1964 Nissan Patrol soft top restoration
RMP&O
Great job!!!! atta boy!!! it's gonna look better than new.....
For your barn doors this link may be helpful....
http://stores.ebay.com/oem-alternatives
http://www.ebay.com/itm/NISSAN-PATR...Parts_Accessories&vxp=mtr&hash=item416b41fa65
Thanks! Geez, first post by you, thanks I feel privileged!
You can be sure though I have been all over the internet (worldwide) and then some finding parts for this project. And those items linked to Ebay I do not need but thanks again for the links.
RMP&O
You should have opted for the wire wheel and 4" grinder. Your getting soft in your old age...
Screw that! It is not my truck, if it was I may be that cheap, even in my old age!
I got a blaster but didn't have enough medium to do this frame or the right kind of medium. Plus it is a messy job, on this truck would rather just pay somebody to do it.
It started raining so I have the frame in the new shop area now. Will be starting in on the things I need to do to it in the next few days. Some welding and few other things, then we got to get some paint on this thing!
RMP&O
So I spent a good number of hours on the Patrol last night.
The shop isn't even done and I am already using it and loving it too! It is small and tight but I got plenty of room to work.
main.php
A detail shot on an area of corrosion, obviously after cleaning it up a lot.
main.php
I think the frame and frame rails all naked like this are just sexy! :cheesygrin:
main.php
I cut the battery box brackets off, man this was a total pita! Nissan really glued these to the frame. I took my time and got them off fairly clean though. All new brackets and a shelf is being fabricated. Glad we did it because there was corrosion in the brackets and also behind them. All clean now and no more rust!
main.php
We got the #2 cross member finished up in terms of welding a few days ago. The whole thing is welded inside and out. Pretty welds....
main.php
And I am using the Utes cross member for reference. It is one of the few I have ever seen that isn't full of dents!
main.php
I have worked the cross member now down to 120grit. It shaped up pretty nice and I am almost done with it. Just a bit more shaping and sanding.
main.php
main.php
main.php
main.php
main.php
main.php
RMP&O
Today's episode was to cut the last bad areas from the frame and make patch pieces for it. I also coated the inside of the frame with Rust Bullet that are open now and hollow, ie #3 cross member, rear bumper, ect.
Here are the rotten areas that had to go....
main.php
main.php
A pretty funky factory weld...
main.php
To get to these areas needing repair I had to cut this piece off.
main.php
Bit of corrosion hiding under it...
main.php
main.php
The other side is good though and doesn't need repair. The side I am repairing definitely held some crud for many years.
main.php
So I cut out the rusty/thin parts...
main.php
main.php
main.php
And I made new pieces....
main.php
main.php
The cap for the cross member to replace the one I cut off....
main.php
main.php
main.php
With all the pieces stacked on!
main.php
Some shots of coating inside the frame and on the inside of the #2 cross member with Rust Bullet.
main.php
main.php
main.php
main.php
In the next few days welding all this stuff on starts!
Cheers
RMP&O
Today's episode is....
Welding pieces back on! The #3 cross member is all done, rear bumper patch is done and both sides in the rear are ready for shackle hangers, front patch on frame rail where bumper/winch mounts is done. Blah blah blah! :roll:
Plating the whole inside cap of the #2 cross member before welding the bottom on. The cap is already new, about 12g. and I ground out the last of the crappy steel under the trans mounts. 1/8" plates going in making the cap now about 3/16's, nice a solid!
main.php
main.php
Going to lay another bead on these where needed and sand more, only about half way done. Still got to trim the shelves too.
main.php
Tossed a weld in the corner where the crappy factory one was at. That was about the only shoddy factory weld I find on the truck. Two others though we are going to lay a bead on to buff them up a touch.
main.php
Got these pieces all glued on and sanded...
main.php
Where the patch was done on the rear bumper and some of the scaring filled in then sanded back.
main.php
main.php
This is the other side in the back that was all scarred up.
main.php
Front frame rail patch done, going to lay another weld on the shackle hanger.
main.php
And the #3 cross member is all done plus ready to mount our new leaf hangers. I am very happy with the results of the restoration on this cross member.
main.php
main.php
main.php
main.php
main.php
Getting close to being done with all these repairs now! :cool:
Cheers
krazytoy
Looking very good my friend. It's amazing all the corrosion that hides in all the little places and under things.
RMP&O
Not much of an update but....
1/8" plate is all welded in the top/cap of the #2 cross member. As mentioned, total thickness now on the top/cap is about 3/16" exactly. A big upgrade from the stock 12g this cross member is made out of.
main.php
main.php
taped it off and painted it with Rust Bullet. It will be hard to get it coated once the bottom is welded on so why not do it now!?
main.php
The bottom of the cross member we have fabricated has now gotten three coats of Rust Bullet on the inside. I also scribed it more to fit the top after the 1/8" plate was welded in. It is now ready tog o and should be welded on in the next few days.
Cheers
RMP&O
Thanks bro, means a lot coming from you!! And yeah, sandwiched steel will have some rust/corrosion no matter what on a 40-50yr old 4wd. Just about got it all dealt with in this Patrol though.
The #2 cross member bottom got welded on today. I think it looks killer! I will still have to sand it a bunch and grind the weld off the edge to make it look as much like a stock one as possible.
main.php
main.php
main.php
main.php
main.php
main.php
main.php
Cheers
RMP&O
You have some mad skills!!
Thank you sir. But just to clarify, I am not doing the welding on this truck. I am doing everything else (besides body work too) but my welds are not up to par for the level of restoration we are doing. I know an out of work certified welder so I gave him some things to do and put some money in his pocket. He likes to work on trucks more then other fabrication work too so it is working out for us both. I prep everything for my welder friend, he simply comes over and lays down the beads, I then clean it all up. Also this isn't my truck anymore, (I sold it) and I require as well as my client requires welds like you see above. In time perhaps my welding will get at least good enough for me to be happy with it, besides that I have got everything else dialed.
Cheers!
RMP&O
This evening was welding fest!! :lol:
Seriously though, we went to town on welding tonight. It is all done now besides the battery box stuff, some wire harness tabs being replaced and any fill in or clean up after I grind/sand things back.
After more then an hour of measuring stock leaf hanger/shackle hanger locations on a 65 frame I have to use as reference, well we decide to just go for it and weld on the hangers. I had planned to just tack weld on the hangers and then test fit everything before burning them on for good. However, it occurred to me during all the plotting of the hangers that as long as they match stock it is ultimately what we want. If shackle angle comes out off it won't be due to the hanger locations it will be in the leaf springs, since we are matching up the hangers to stock locations. So it was decided to simply glue on the hangers in the stock locations and worry about if the leaf springs are right later rather then trying to compensate for off leaf springs by moving the hangers now. Since the truck is a restoration to stock the hangers need to go in the stock locations and leaf springs need to suit this, there is no other way to go with it. So after a bunch of plotting and such we burned on the hangers....again I used several things to get them in the stock location. One being the 49.3" spread eye to eye as per the Nissan manual and the next being locations on the 65 frame of the hangers used for reference. I got so say, if this wasn't a restoration it would be easier since I wouldn't be so worried about things matching up to stock. :ugeek:
The front leaf hanger on the back leaves burned on.
main.php
Another view...and the other side.
main.php
The RuffStuff way back shackle hangers glued on solid.
main.php
All four hangers on and ready to rock...
main.php
Holding the rear Alcan leaf spring in place. It is square, it lines up but it looks to short! Can't jump to any conclusions until all the weight is on the springs.
main.php
The rest of the pictures are just of welds and such after the frame was flipped over. By the end of this coming weekend I plan to go over everything with a grinder and sander and clean it all up. if I am lucky we will get the battery box fabricated and be just about 100% complete with frame resto by then too. But ya' know how plans go with a restoration! :roll:
main.php
main.php
main.php
The booger welds on the #2 cross member side and top are to fill in imperfections. Clean up with grinder/sander and it will look much better.
main.php
Repairs from the topside, details...going to be some fun grinding and sanding this all back! :shock:
main.php
main.php
main.php
main.php
main.php
New school meets old school!?
main.php
The NOS leaf hanger....
main.php
The frame right side up! ;)
main.php
Cheers
RMP&O
I put in a lot of hours on the Patrol today. It doesn't look like much in the pictures because it was all slow detail work!
I added some new 3/8" drain holes directly behind the leaf hangers.
main.php
main.php
main.php
I ground the #2 cross member weld back all the way around with the die grinder...
Before grinding
main.php
main.php
And after....
main.php
main.php
main.php
main.php
main.php
I also worked the top of the #2 cross member a lot today, flipped the frame over, I didn't do it on my back!
main.php
main.php
We are going to weld all the way around the #2 cross member again and then grind it back again. After that work it with the sander along this edge. Point of all this is to make it look like a stamped out section like it was stock on the truck.
Cheers
Henrybrowne
