Grandpa Builds A 2000 Montero
MontyMcV
I may paint them in the future...
Here's my OEM 7"s painted in black, color keyed to the trim on my 95, then clearcoated. I got them used and they were rough. Had them sandblasted first.
grandpa
With it getting dark earlier, and with the active wildlife around home, I added some better lights. A pair of Hella 700FF.
grandpa
The steering has felt a little loose so I replaced the tie rod ends and the ball joints today. Does anyone know if there are any alignment adjustments on the front of the Montero, or just the toe-in? Thanks.
RU55ELL
Alignment specs for your Monty from 4x4Wire:
Mitsubishi Montero:1992-2000
Front : Left and/or Right (Both sides identical)
Camber Spec. 0.7* +/-0.5*
Caster Spec. 3.0* +/-1.0*
Toe Spec. 0.14* +/- 0.14*
SAI Spec. 14.9*
Included Angle 15.5*
Turning Angle Diff. -1.93*
Cross Camber
0.0* +/- 0.5*
Cross Caster
0.0* +/- 0.5*
Cross SAI 0.0*
Total Toe
0.28* +/- 0.28*
Cross Turn Diff.
N/A
RU55ELL
Oh, and leave the wheels stock. It looks better, IMO. The whole black wheel thing has played out a couple years ago as far as I'm concerned.
BIGdaddy
Really does look great. So, i thought gen II.5's came with rear lockers with the winter package...(heated seats and all that). Is it only 1998 and 1999 gen II.5's?
grandpa
I think I'm up to date on maintenance.
Last weekend I did the ball joints and tie rod ends.
This weekend I replaced the timing belt, water pump, cam seals, crank seal, hoses, spark plugs and wires, and valve cover gaskets. I'm glad that's done.
Henrybrowne
