Hello guy, newb with 89swb bone stock and ready to rock
TheAntiChrome
Hi, my name is Joe and I just picked up an 89 Raider due to a very fond memory I have of wheeling one with my dad when I was young. This one is blue, bone stock, 200k mi, and was mine for the hefty price of $300 with a bad motor. I have another motor sourced (actually an entire d-50 with a Weber and 31s, plus a 3" BL that may/may not swap) for $300
I have sourced 16" Toyota steelies and 265/75 BFG A/T's for it already, if the 31's prove to be too dinky.
The questions I have:
In a local yard is a nearly un-picked 6/93 SR with and auto trans. The only thing that looks to be pulled are the dash guages. My *question* is about whether I can swap in the rear locker without converting to the entire axle w/coils (mine is obviously leaf-sprung).
Also, is there anything else worth pulling to swap easily? That is, besides the front suspension and brakes (I **DID** search a bit before posting). Specifically will the bouncy seats/rails fit? My rig sadly does not have them. What about the back seat? its very very nice and reclines. I bet its too wide but still, gotta ask and I can exactly drive my rig there yet. anyway, its all there... engine/trans/tcase/axles so I would like to know what to pull before its all gone. steering wheel maybe?
Third, what is the proper designation to use for google searching? gen 1/gen1/genI/gen 2/gen2/genII??
Finally, There is also a 2000 sport with no motor and some bad rearend damage, anything useful in that? maybe the tall console lid? foglight switch? from my quick glance those looked nice.
Thanks and I look forward to becoming a post-whoring fact-monster myself one day, like I see a few of you are already.
rxinhed
Dirt Guy
The '89 Raider is a Gen I Montero. If you have a leaf spring rear suspension (4-cyl.), the Montero Sport rear axle on a leaf spring setup is a match. If you have coil rear springs (6 cyl.), the Gen II (92-97(ish)) Montero axle with air locker bolts in.
Welcome. ;)
TheAntiChrome
To revive this thread since I am nearly on the road:
In a local yard is a nearly un-picked 6/93 SR with and auto trans. My *question* is about whether I can swap in the rear locker without converting to the entire axle w/coils (mine is obviously leaf-sprung).
On that last note... I cannot for the life of me find a decent writeup on WHAT PARTS need to be pulled for the upgrade. I plan on doing a mild T-bar crank and will need to correct the camber (right??) and I would not be against having larger brakes.
Justice R
Short answer on the SR axle into a 4 cyl is no you cant. The axle shafts are larger and the third member wont fit into the 4 cyl housing. If you feel like grinding off all the spring and shock mounts it is possible to swap the entire rear end assembly with a lot of work and modding your drive shaft.
If your looking for bolt in, you need to find a leaf sprung Montero Sport with the locker, and swap out the whole rear end.
TheAntiChrome
alright Thank you for the heads up. Now on my short list of wants is a 97-99 Sport, correct?
PROGRESS so far:
I scored two bouncy seats at the yard the other day, one 6-bolt from a '90 and the other a 4 that was practically rusted into the '84. $15 apiece was more than fair. I also nab the metal grille from the 84 (no badges on it though) and am really thinking about going back for the stubby rear bumper.
I pulled the good motor from the donor pickup, blasted the mud off, and am preparing to eliminate the balance-shafts, replace the water pump while I am in there, as well as the pan gasket, the front and rear main seals, the intake and exhaust manifold gaskets, and the plugs, wires, cap, rotor, and all belts. Did I mention I work at a parts store?
I also obtained some 285/70r17 Cooper Discoverys on Toyota FJ cruiser steel wheels that I plan on painting white if I can find the wheel spacers that allow them to fit over the hub. should look pretty cool with the metallic blue paint.
NOW FOR A QUESTION:
To confirm with you gurus, I just need to crank the torsion bars up a it, put lift shackles in the rear, and swap in gen2 UPPER control arms to correct the camber? is that it?
Thanks guys.
off-roader
NOW FOR A QUESTION:
Thanks guys.
That should work. Remember don't crank them too much or you may have CV issues.
TheAntiChrome
Hey guys long time no update. Just as I finish up the rebuild of the g54b the shop where I have been working on my rig decides to move locations, so now I am at a point where I start gathering parts for the next upgrade.
I went back and really looked over the 94 SR from the yard and found that it had a few goodies. I got the bouncy seat rails and the factory adjustable shocks to hoard away until I find a suitable gen2 or sell if I don't. Time will tell.
What I need advice on is the axles. I found out that they are 4.875 ratio so I want them for that at least, or do I? What size ring gear are they? Will I be able to swap the gears into a locked rear diff in the future? The rear has a V62 code and the front is FC1 if that helps. I can get the rear with the lower arms as well as everything in the front from hub-to-hub including steering stuff for $200. I figure its worth it for the brake upgrade and uppers arms alone, but I want to be sure I am not buying stuff I can't use later.
Thanks
iStan814
