Laforza..the Italian stallion? Italian SUV with a Ford 5.0 (not mine)
nely
Ive worked on a customers from time to time. Good luck finding suspension parts. Brake pads from the iveco dealer can be expensive. They are just a pain.
Toyotero
That looks like a parts scarcity nightmare... and kind of like an Isuzu.
I think I'd rather get a Lamborghini LM002 "Rambo Lambo"... at least it'd look the part too.
!!tMUEmw!W0~$(KGrHqIOKoYEz!t)iQc6BM5UBqs6KQ~~_27.JPG !!pmiD5QCG0~$(KGrHgoH-CoEjlLluzl+BJvlI(YzG!~~_27.JPG
!!tMT7SQ!m0~$(KGrHqQOKioEzWWfz!!HBM5T-EZyk!~~_27.JPG lm002-lamborghini-built-for-sultan-of-brunei-for-sale_1.jpg
njtacoma
I've never seen a wagon version of the LM002 like that before, it seemed like all the magazines tested the one with the trunk/bed.
I don't think the wagon helped the looks, but I'm not in the market for a Laforza or a Lamborghini
Rattler
Thornton Melon's Kid
I had to double back the first tiime I saw a Laforza because I had no idea what the hell it was.
I remember when one of the guys from Car & Driver drove one through our town on his test trip. I talked to him for a couple minutes.
Lemsteraak
Not a bad buy, actually has some very good parts. The main problem is just that, it is a lot of good parts and designed by the fellow who designed the Pantera, so it sounds good. Lacks integration, but if you look at what they did, with what they had, it was pretty incredible. A small Italian company, Rayton Fisorre, designed and built it with about 20 people back in 1985. They were a design house previous to this. If it looks generic, it is because elements of their design were incorporated in later Range Rovers, Isuzus among others.
Tom Tjaarda, the designer, and American in Italy, pretty much penned it by himself. The construction is really strong, it uses a cut down IVECO Daily 4x4, medium duty, chassis, and has a body that is like a monocoque, so the body keeps the chassis from flexing. The base is good for a off road build, since it is a cut down chassis, and the turning radius is about the same as a VW Rabbit. Because is is truck based, the axles are huge with posi traction front and rear. The differentials are even vented up into the body for water crossings. Seriously strong.
The main downside is that if you look at the list of parts, it sounds really good, for example Momo steering wheel, Blaupunkt Radio, only just try to touch both at the same time, ergonomically challenged. Development was stunted too. so headlamps are dim for example, there are relays but for some reason, not used. The reason why a Laforza is a collectors item and not a serious off roader, you don't want to have to replace the windshield for example. Comes down to parts, off-roaders need to have parts that are cheap and plentiful, a Laforza has neither. Better off with a Ford Bronco, same running gear but you can replace a windshield when the need arises.
zimm
interesting 5.0 intake. i never saw one like that.
i think the "electrical fire" is hysterical.
kingg5
looks just like the lightning intake...well similar haha either way...its def one of the truck intakes..not the 5.0 car intake.
xander69
