Crossing oz south to north in a stock fg637
SkiFreak
Crazy Person
Maybe you can use one of those inspection cameras to see what happens at the ends of those pipes.
blackduck
Well heres the Tank after some quick measurements....Its gonna be tight.
Pretty safe to say these J brackets aren't going anywhere
Bit confused as to why there are three holes in the top plus sender hole. I thought 1 for pickup 1 for return. Maybe 2 pickups??
Shannon are they holes or hose connections
a lot of truck tanks have remote breathers so youd have a pick up, a return and a breather
Tonkatuff
Ahh now understand. Now I've just gotta do it. I'll keep you posted.
Sent from my RM-821_apac_australia_new_zealand_218 using Board Express
Tonkatuff
Alright tank fits
Even two bolts on the j brackets line up. Had to cut and shut the side rail but looks good. Just need to pick up some hardware for the Breather and fuel lines and rock and roll.
Amesz00
How many litres is the tank? If its over 200 I would suggest getting another J-bracket and using 3. And try to make sure 1 bracket lines up with a chassis crossmember. Canter chassis' aren't the greatest, and all the weight is hanging off the side. Just something to consider.
Andrew.
Tonkatuff
Tank is 260, the front bracket will line up with a cross member I was thinking of putting a second tank on the other side and putting a frame between them.
whatcharterboat
Sounds good Shannon IMO. Have seen not good setups with big tanks on one side only and the unbalanced load causing the suspension to list. ....if you're going to build a frame it should support the chassis from the downwards force of the heavier tanks.......the plates at the end of the crossmembers are where I have seen damage as a result of tanks bouncing.......that's the plate directly behind the tank bracket.
Regards john
Tonkatuff
I dont think listing will be a problem as the other side of the truck is the hydraulic pack and the majority of my tools. i want to make a frame to go on top of the tanks, to make up for not being able to fix to the tray and make it span the whole vehicle.
blackduck
I compensate uneven load with the wife :victory:
Tonkatuff
J spose you've got 2 positions, centre and passengers seat.
alan
Finally got to measure a Canter front shocker today, they are the same as a Toyota Hilux front shocker 81-88 model with leaf sprung front end, so there are dozens of options available.
seth.c96
