monkeyplunger
I also installed the bestop underseat safe. I had it in my 2010 and installed in about 15 min. The 2013 took over an hour. The 2013 now has heated seats and side mounted airbag which now puts electrical connectors under the seat which were not there in my 2010. This required me to remove the oem bracket and mount the airbag and heater connectors directly to the safe.
OEM underseat bracket. It is bolted to the drivers side slide rail and is easily removed.
I copied the hole pattern to the side of the safe and checked to see if the fir trees would clear the drawer. there is about 1/2 to 3/4 clearance between the drawer and outer shell.
Here is the safe installed under the seat with the airbag and heater connectors mounted to the side.
Asides from the two connectors this one is easy.
