I agree, I have 280,000 km on a 2000 D2 original engine, original head gaskets, run on dex cool and no problems. Always used synthetics and followed maintenance intervals. Just developed a small oil leak in the front cover so I will swap timing chain and gears and put in a new oil pump. The problem with dex cool was the gaskets used in some GM's as long as its changed in time I believe it's fine.
			Yeah...the plural of anecdote is not data, and dexcool is not what kills these motors. I will agree that dex tends to turn acidic faster when there is air in the cooling system, and the D2/P38 cooling system is problematic to bleed so this is more of a factor......but it's not the problem.
That's great that yours runs well. But like I said before, tolerances were little better than luck at some point as the tooling was obviously worn out and not being maintained towards the end of the line of these motors.
OK....I'm not even sure why I responded to you with any sort of though when you are just trying to be inflammatory...but whatever.
That's not just your theory, it's a fact. They were run hot for emissions and to juice the last bit of performance they could get out of them (on the cheap) the attempt to be competitive with modern offerings. There is no excuse for the different between "normal operating temperature" and "oh ****, I just melted a piston" to be as close together as they are on the Bosch motors other than a massive compromise for something that should have been replaced long ago.
