86 Land Rover Defender 110 shop truck project
flipstah
Leaks.
I totally forgot about the glass fuses until I saw your new post.
Fuse boxes are easier to replace in a pinch because if you don't have a spare, you can use a staple as a connector ;)
AndrewClarke
Great idea! Now I can replace the spare fuses I keep in the truck with a stapler! This will be a big help whenever I'm out on the trail and think, "now how am I going to keep these two pieces of paper together?"
AndrewClarke
Hmm, thanks. I've already placed my order, and 20 C228s are going to cost me > $30 with shipping and tax. Are they a requirement or just nice to have? I ordered 60 of the c226 terminals, which gives me 50% more than I theoretically need.
A junkyard 300tdi ready to get torn down and assessed
This R380 is from a discovery which won't drop into a Defender because of the shifter location. However there is a easy way to fix this
This adapter from Ashcroft lets you use your Defender shifter on a Discovery gear box
The defender and discover shifter side by side
The tdi still has the older problematic timing belt pulley, this need to go
A new genuine Land Rover timing belt update kit
There is something very comforting about using genuine parts
The cylinders look to be in good shape with little wear
After the motor is resealed and a new clutch installed it is mated up to the transmission and transfer case
A new bulkhead extender needed when converted to 300tdi
new door shells
The seat boxes were bead blasted and galvanized
The seat box needed to be swapped out to a newer unit to accommodated the more forward position of the transfer case when mated to a 300tdi
superbuickguy
nice work. Do you have a picture of the left side of the motor before you put it in? I've been bumbling my way through a 300 tdi swap into a Discovery 2, and a picture would answer a thousand questions :)
ZG
Busy Fly Fishing
Left side like turbo site? My 300tdi is still on a pallet if you need a photo.
crostopher
