Cole
A little Eurovan progress today.
First off I accidentally bought another Eurovan:coffeedrink:
1993 5cyl MANUAL transmission van. I figured I could take a couple of key parts off of it for future use and part out the rest of the van. The manual won't work with my VR6 but it will work with a TDI or I can use the lever and pedals for a future manual swap with the VR6.
The late model van like mine don't have a glovebox! Just a knee bolster. From what I have read you can mount the early glovebox in place of the knee bolster. Wish I had known that before letting the glove box go to the crusher with my first donor van.
This van also has a desirable crankshaft from the 5 cyl that I hope one of my Audi buddies can use for a turbo stroker build.
Or.....I could do a sold axle swap, lift it up high enough to stuff a longitudinal driveline in it and go wheelin!
I did do some very important mods to my van today!! I installed the bottle opener!!!!
Found an idea spot inside the sliding door. Puts the bottle opener in easy access from the outside of the van, or seated on the backseat with the door open. Should also drop any foam outside on the ground!!
With the door closed it will also be accessible even with the bed pulled all the way forward!!
The mount used one of the existing interior panel screws and one new one screwed into the door sheet metal. This location put the opener just a touch too close to the weather stripping when closed. So I had to trim the opener just a touch to make it clear.
I also replaced the broken stock cup holders with some from ebay for $4.50 each. They didn't fit perfectly, but they will work fine for the moment.
