AmboVan Restarted
steelheadbum
Rig looks baaad to the bone bro
Buck
The Redneck Mexican
2002 E350 7.3 PSD 4x4 8inch lift pop top conversion....
hobietony
Using (and fixing) it again
Just got back from Galveston, and I see I day I left I wrote the following - "But it is all pretty much refinement at this point"
I suppose that is true, but I had to do a bit more on-road refining than I expected...
Got the airbags installed and all hooked up the week before we left, pretty easy since the airlines were mostly run, and the switch and gages have been installed for a couple years now
More on this in a bit.
Got about 1.5 hours out of Tucson, smelled coolant, checked it out, went back and had a new radiator put in - All metal this time, and able to be done by my usual guy, so could have been worse. The plastic tank on top had cracked, but not burst, so I could make it back.
Thought we might take the scenic route getting out there, but the initial delay kept us to I-10 for the rest of the trip. Slept just off the road in quarry/dirt processing area outside of Fort Stockton. Wide open West Texas, in the morning, the creosote bushes stretching out to the horizon looked like the ocean, nothing manmade to break it, pretty cool. Another 12 hours of freeway and fuel got us to Galveston with no further incidents
Just a few pics from the week -
Bit of Rain
Bit of Carnage
A few more
A bit more refining on the way home,
3 failed tires, 2 of them changed, and limping in on a damaged third.
Also lost pressure in one of the airbags while still in New Mexico, went to check it out, and found both bags had slipped off the floating base, one was punctured, and one was wedged all sideways. I didn't really notice anything until it failed, they were still applying pressure to the system, but not on the proper surfaces.
I'll need something a bit more positive to locate the bottoms of the bags over the axle, maybe some sort of raised ring? I'm sure the heavy loading is a factor.
Speaking of which, I took the van over a scale on the trip, fully loaded, trailer attached, full of water/fuel/etc. It is a bit more than I expected, although my expectations were only based on 'feel'.
The rig
The weights
:Wow1:
ujoint
Supporting Sponsor
Have some of them on order, redesigning the lower mount to use them. I've had one bag pop out like this, on another ambo.
Is the gutter mount the only thing supporting the weight of the roof rack? I'd like to do something similar (currently losing an entire compartment to the spare tire and jack) but not sure how to attach it...
hobietony
I have a set of steel 19.5 rims at the house. You are going to need them with that porky pig.
So, something under 14k without the trailer - wasn't yours close to that?
Can you tell us more about the tire failures?
Do you have a plan going forward to address the tire issue?
So of the original 8 tires, 6 have been replaced so far, generally under warranty. I never covered the tires, they had long periods of inactivity, with periods of long hiway miles, or runs through some pretty rocky terrain, so I am hoping that the new ones will perform better with a better use pattern. I put the two remaining original tires on the front, because I can feel the failure start in the wheel, cant feel a thing if it happens on the rear. I expect the two on the front to fail soon, but Discount wont replace them until there is actually a problem. Vehicle weight is well within the stated capacity on the tires, so if the new ones start failing then I have another issue. Either way, I have a lot of new tires to wear through before I need to consider bigger wheels/some other option.
Check out post # 321 in this thread. It is partially cantilevered from the ambo box, most fasteners are in the ambo framing, I tried to drive as much load as possible into the box and not the gutters. Those gutter mounts were actually floating over the gutter before I clamped them down. (and of course, before any load was added to the rack)
hobietony
And, just wanted to say that Chris has been great regarding the slipped bags, he is working on revising the lower mounts, using the base talked about a few posts up, and working out something fair for the bags themselves. I mean, we all know he is awesome, I'm just confirming it.
Ozrockrat
Yep pretty close to that. It only took 1 blowout with the E rated tires and I figured I wanted something with more safety margin. Oh and speaking of porky pigs. The ambo the color of snot is on its way.
xander69
