2004 Discovery
Said they where going to drop the price. But the owner does not seem trustworthy so I am no longer looking at it. I called the "dealership" they said that did all the work on it amd the number didn't work. Sketchy
Sent from my SAMSUNG-SGH-I317 using Tapatalk
brushogger
Maintenance records; the more the better.
It will need a head gasket job. Not if, when. If it's ever been run hot you'll eventually need a new engine. Some fail without even having been run hot.
Also, a front driveshaft with greaseable U-joints is a must. The stock unit will grenade and take out the transmission.
This x2! Ask me how I know. If you can get it cheap enough to put in a cannibal (or equivalent) engine though it would be ok. I loved mine until the liners started letting go.
11b4v
Yes I am. Did you see the disco at the lemon lot or did you just recognize the lot?
Thanks everyone for the info. I'm going to call the dealership, that has done all the maintenance on it, tomorrow to see what has been replaced recently.
I reconized the lot/background.
Take a closer look at my avatar.
Been there, done that.
Goldenbora
