Show us your Toyota 4runner, tacoma or truck.
Revco
Little update on my Tacoma...
Finished modifying my Leer camper shell. It was for a Ranger and didn't fit the cab profile, so I cut and re shaped the front corners, filled a hole in the roof, and made a recess for the 3rd brake light to clear. Then I coated it in Rustoleum Bed Coating because I wanted a durable paint with some texture to hide the blemishes, but not too rough like most spray on liners.
Then I installed my Bilsteins 5100's with a pair of stock Tacoma coils. I was afraid that an aftermarket coil would make the right rough so I figured id try the stock coils first. On the top groove I've got 2.25" of lift after settling. Much smoother than the worn out original stuff.
In the rear I built some frankensprings using stock Tacoma leads with some 3/4-ton Chevy leafs trimmed and stuffed in. I put them in and gained 4" of lift in the rear. I had to cut the tailpipe to clear the spring.
Now the shocks won't fit. So I pulled some measurements at ride height, stuffed, and stretched. Got some universal axle mounts and some cheap 10" travel shocks and went to town. I ditched the spare tire carrier and had to cut the tailpipe again even shorter to clear the shock.
Rides great, flexes great (need longer rear brake line) and should look great when I toss the 285/75/16 MT's on....
Shell...
5100's...
Rear...
onemanarmy
Picked up this 86 22RE 5 speed a few weeks ago. Need to get my other project out of the garage (FJ55) and then its mod time. Just driving it to work a bit to work out any little issue. And it has some.
voodoojk
Matching paint and wheels looks much better together than on an FJ lol
I honestly would prefer the black ones but these came on the truck when I bought it. I thought about powder coating them
I need to get a slight lift and waiting for my new mud flaps..then flat rack or basket on roof?
Subspd
Black wheels are a dime a dozen. The gunmetal you have look much better. Nice looking truck!
Hanks94
I've been admiring all your rigs for a while now and thinks it's time to show off my modest 94 XtraCab. I bought it a few years back with 130k original miles on it and a 3" block lift other than than completely stock. All I've done to it is remove the block lift and keep it at it's stock height for now, added a front winch bumper and rear Trail-Gear bumper, and added a camper shell to sleep in when I go hunting/camping. The shell color doesn't match but it does fit the truck and I got it for dirt cheap on CL so can't complain. Definitely have more plans for it but till then it gets me anywhere I want to go just fine and never gives me any problems.
toyotech
That is why all my wheels are done in gun metal and most my armor as well.
Houie
