1998 4Runner (L.A.M.B.) is officially for sale
bikerjosh
Sold pending funds
L.A.M.B. = Locked, Armored, Methanol Injected & Blown
Updated price 12.5k obo
Engine/Drivetrain/Brakes
• 3.4 motor 165k (timing belt and wp changed at 120k)
• 2nd gen TRD supercharger
• URD 7th injector/fuel timing calibrator
• URD 2.2 pulley (more boost)
• Devil's Own progressive Meth system in cab control
• OBX headers
• Custom intake tube
• Custom exhaust routing protected by rear bumper.
• Level 10 valve body upgrade for tranny (no trans slipping w/extra power)
• RV sized trans cooler
• ARB air lockers front/rear
• 4.88 Yukon gear sets front/rear
• Crmo rear axles
• Front Tundra 231mm brakes (less than 5k miles)
• Rear disk conversion Eldorado frt calipers
• 76' Chevy Blazer brake master cylinder (pushes more fluid for the disks)
• Scan Gauge (may remove)
• In console tranny temp, AFR, and boost gauges
• Safari snorkel
• 1 yr old Diehard Platinum group 34 (may remove)
Suspension/Lift
• 2” body lift
• LR Racing adjustable UCAs
• Custom HD front sway bar links
• Toytec 3” coilovers
• Blistein rear shocks
• OME heavy Springs
Armor/Recovery
• Front ARB bumper
• Rear CBI bumper w/swing out spare tire and single can.
• 4x Innovations weld sliders
• Skid plates:
o Front-Savage 2 piece
o Steering rack Lil Skips plate
o Belly plate Lil Skips
o Gas tank plate Lil Skips
o Rear LCA skids Lotus Engineering
• Warn 9.5 ix winch w/synthetic line (may remove)
Rack/Lighting/Electrics/ETC
• Full length WMW rack with sunroof cut out and custom adjustable cross bars
• Blue Sea 6-place fuse box in engine compart
• Two Hella Super tone horns (loud!)
• Satoshi grill mod (not sure how much horse power this adds)
• Two Hella 700 -55 watt HID lights mounted to front bumper
• Four red ring 35 watt HIDs mounted to rack
• Four LED 4” lights one on each side mid rack and two facing rearward
• Cobra CB mounted in ash tray opening
• Outdoor Logic rear antenna mount
• Apline DVD/NAV/Bluetooth deck-upgraded the NAV cartridge last year 2013 maps
• 5 Mikey Thompson pro comp wheels w/295/75/16 tires 20k on 4 tires, spare and one of the procomps zero miles
Can include an MSI netbook for programming URD injector and data logging
I'm sure there is more, that I am just forgetting,
Here are a couple pics, I'll take better ones over the weekend.
In spite of all the extra weight this 4runner moves quite quickly. This 4runner will go more places than most out there and not look out of shape getting there.
Why am I selling? Just bought a 2006 Tundra dbl cab to build up for my family. Don't need to sell this but don't use it enough, need more drive way space and I own too many cars/ motorcycles.
$13k pretty firm, but willing to listen .
New Price $12.5k with everything
I will likely pull the Battery (switch w/1 yr old interstate), scan gauge, and the winch if it doesn't sell right away and use them on my tundra build
Thanks for looking -Josh
whammo
yep, Mengel Pass from earlier this month and steel pass from November.
I was there in Feb. Beautiful drive.
I'm sure you went thru quicker than I did....
Great looking and awesomely set-up rig.
Wish I was in the market.
GLWS.
Josh
bikerjosh
More pictures after a quick wash
If you are looking for a stealth 4wd rig to blend into your surroundings, this isn't it. Almost every time I'm driving this in town people stop to ask me questions or snap a pic or two. No joke even had some girl at Stove Pipe Wells hop out of her subie and snap a bunch of pictures of it. don't like the attention or interaction with people just keep the windows rolled up everything other than the windshield has pretty dark tint.
Driverside from
Driverside from rear
Passengerside from front
Passengerside from rear
LED light on rack, four of them total 2 facing rear, 1 on each side-bright
Switches for Front/Rear lockers, Compressor, under the lockers is a switch for the 4-35watt HID roof lights, red switch is for the 2-55 watt bumper mounted Hellas, side and rear LEDs have a switch on the center console. ( all lights on separate relays, fused through a blue sea fuse box)
Audio/Video double din deck, Cobra CB, AFR gauge, Boost, Trans Temp, Progressive Meth controller
Skid Plates
skibum315
Not especially looking, for myself, but this seems like a well built truck ... and a bargain for what it is. How's it tow with your mods? What was the factory ratio, and how's the highway ride with the 4.88s?
Looks like you have a few other nice toys, as well (the Seven in the garage caught my eye ... and the lavender fender with the black wheel certainly isn't sitting at a factory ride-height; S2k? Miata?).
Good luck with your sale, I expect it should go fast at this price ... hope you get out of it what you're after.
PTB
glws! I've traveled with Josh and his 4runner a few times. It made short work of everything we encountered.
bikerjosh
replaced cup holder
Finally got around to replacing the original broken cup holder. Now even more of a deal. :sombrero:
Josh
bikerjosh
Replaced Thermostat w/170 degree unit
Swapped out the thermostat that went South on an earlier trip and I had to replace with a standard unit available at a local autoparts store in Bishop CA.
New unit is a performance 170 degree thermostat from URD. As a bonus I'll throw in the sticker, hell you can even have the stock thermostat w/2k miles.
Bump, Josh
PNWav
