Aux switches
corbinwalp
Where do ya'll have your aux switches installed in your Discoveries? I have three near my sunroof switch in a custom plastic housing. I'd like to install some more when I get aux lights but don't know where to put them.
454
Exploder
There's a factory three-switch carrier that replaces the ashtray or the coin holder. It's for the D1 but is a direct fit in D2's. Expedition Exchange carries them.
How many more auxiliary switches do you need? Be careful or the interior will begin to resemble the flight engineer's station in a B-52.
corbinwalp
Perfect! haha
ZG
Busy Fly Fishing
I took the factory D2 6 switch bezel, cut it up and put a new faceplate on, then cut that for the switches. I also cut holes in the non-A/C roof panel.
Disco2Guy
You can use the binnacle switch blanks on the left of the steering wheel. You have to use a cruise control switch, but can use any of the covers, and wire them to a relay. EE carries everything you need for this option too.
Here's my rear work lamp wiring diagram, and install. Under that are the switches for the center and outer HID roof rack lights.
https://picasaweb.google.com/106948703837045040021/RearWorkLight
94Discovery
terrifyingly beautiful
I will have in it all switch formlight fog bumper rouf rear under cariage plus 4 integrated usb,battery cut off ,battery voltage ,throtle control for winch and air compressor,winch in winch out ,light indicator if the coolanr drops ,and som extra stop,
I was going to use all the spaces in the dash but you end up one on the left and one on the bottom,etccc,plus i have my cb on the overhead center console .go Big and never go back ;)
sedat
They're not wired yet, but plans as follows:
1. On board air
2. 120v inverter
3. rock lamps
4. roof lamps or aux.
ZG
Busy Fly Fishing
1. On board air
2. 120v inverter
3. rock lamps
Do you have a D2 radio in your D1??? Please tell me it was easy, I want to do it.
sedat
Yep!
It would have been easy had the PO not ruined the friggin harness!
Its basically plug and play.
I did it to add ipod functionality via a BMW integration unit. You can kinda see it in the bottom right corner.
I finalized the d2 seat switches today too.
dhuss
