2003 Unimog U500 Mercedes-Benz Freightliner 33k GVW 6900 mile
pugslyyy
EDIT - this was pulled from ebay (the emergency lights/siren still being functional violates some sort of ebay rule) but the seller has listed it directly on expo.
Wow.
http://www.ebay.com/itm/2003-Unimog-U500-Mercedes-Benz-Freightliner-33k-GVW-6900-miles-/121387937126?&_trksid=p2056016.l4276
pugslyyy
Am I right in thinking that this one cannot be registered in CA because it is over 26k GVWR? The way I read the regs it would have to have a particulate filter retrofitted to register, and the motor replaced by 2021?
Of course, if you convert it to an RV that's a different story, but I think you would have to do that before you brought it in state.
(Have a friend in CA considering a mog so have just been keeping an eye out. Those CA laws are screwy!)
mhiscox
Exp. Leader Emeritus
Also, unless/until converted to an RV, I'm thinking you'd need a Commercial Driver's License from your state; the requirement is triggered at 26,001 pounds Gross Vehicle Weight Rating, I believe.
Some U500s are 26,000 pounds GVWR. I've no idea if derating a 33K unit to 26K is practical or whether your state DMV would be influenced.
pugslyyy
I expect it would not be a simple process, if possible at all.
MT6bt
Rock hound
Yeah isnt it wonderful that the.most backwards progressive state in the country is responsible the emissions standards of the country. Ugh....what a joke.
V45W_Proto2.5
