rear hub swappin?
QCAuto
My 01 has rear disc hubs, can the hubs be swapped with same year F350 to match the wheel pattern of the 99-03 front D60?
QCAuto
K thought worth the ask, what about redrill the vanhubs and use the truck rotors? I will get specs on each rotor when time to see
ujoint
Supporting Sponsor
That won't work either, the e-brake parts inside the rotor are different between the 2. Like Baja said, wheel spacers/adapters are the route to take. Or swap the whole axle.
iStan814
