If its something you want to look better that is actually in pretty rough shape and you want an inexpensive solution,  then I get it. You will just have to keep tuning it up periodically. If you want to fix it right and for the most part be done with it good industrial paint. Done forever (I know nothing is bullet proof) would be powder coated. Each choice has its plusses, just depends on what you want finished product to look like. Just seen a lot of DIY bedliner uses and it  can be pretty ugly. I've even got creative with some bed liner but not a far of it in raw form on outside body or components that would be hard finished. I had great luck restoring some rough interior panels with it but I always do 3_4 coats of paint over it to make it less flat. So every particle doesn't cling to it. I think Larry has it on his rocker panels but I think he painted over to color match it too.
Anyway it will look good however you choose,  attached to that truck. Especially after the lift. Your almost done with the install right? I would be in serious getter done mode if I had it sitting there looking at me. Looking forward to seeing it. Imop your motor actually makes your truck cooler than if it had an ls swap.
