LED Light Bars; Post Up Pics
Sin
I used to run PIAA 510 Ion Crystal Fogs in my bumper
These were swapped, in place of my PIAA 510 Fogs
https://sneveysoffroad.com/shop/highlander-black-ops-4-5-pods/
7 5W CREE LEDs
4.5”
Flood, Spot optional
Raw lumen: 5000 lm
9-32V
Aluminum casting
Clear Optics PC lens
Operation Temp: -40˚C-150˚C
IP 68
2 Year Warranty
Good price, perfect size.......and GREAT lumen rating!!!!!!!!
Hmmm, I searched that site and it looks like they don't have that exact style anymore
BTW - damn nice rig! That front end shot means - "Get the ****** outta my way!" haha
Here's my JKUR with Jeep light bar, Rigid Lights (20" and Duallys - 2 clear and 2 amber - middle two) plus one Dually (clear) mounted alongisde each A pillar in front of the mirrors (on KC Hilites brackets).
Note that the A pillar lights look distorted but they're just like the other Rigid Duallys.
Nice set up! I would prefer having separate lights like you got, in case one quits working, you still have ample light.
I had my 140A take a dump too. I up graded to a 250 amp from righttoolusa.com . The first one they sent had the wrong regulator. That was corrected pretty painlessly. Made an improvement for sure. Filled the need and no voltage drops when pushed as I had been suffering before. The GM alternators are pretty reasonably priced. Good place to spend a few bucks when the time is right :)
Really good prices on that site, hard to find the 250a your talking bout though haha. I'll keep looking though! Thanks for the info!
HenryJ
Did you upgrade the wiring also or just swap in the larger amp alternator?
Mine came stock with the 140 amp alternator and has sufficiently sized wire for the loads. ( Wire gauge tables ) I did add larger wiring with the auxiliary battery and the charging isolation solenoid. So, long-story-short... I just swapped in the alternator :)
BLT Offroad Avalanche
I don't see mine there anymore either. Check Amazon. I see some good prices for the 250 amp alternator there too.
hitek79
10 inch Rigid Hyperspot/driving combo in the center, then flood dually's on the outside. Crazy coverage. I'm going to throw a 30 inch single row hyper/driving up on the roof rack.
Tacoma13SR5
Simple 20" Rigid SR-Series spot/driving pattern on the center bar and recently moved my Duallies into the fog light ports. Ordered PIAA 570 Led Driving lights for the roof rack.
D45
It took me longer to measure and check the alignment about 10 times before drilling the two mounting holes
I used stainless steel bolts, ss washers, and those nylon insert ss nuts......with some blue Loctite
I just need to wait for it to get dark out so I can align the pattern to the road
A huge thanks to Trail Worthy Fab for the light bar.............dual row 3D Cree 180W and 13,200 lumen
Even in the overcast weather, it is stupid bright
Yes, I can still access the bumper's winch cover plate
WagoneerSX4
Anyone else notice that these polycarbonate lenses are magnets for salt? Anyone have any success with waxing the lense to prevent this? If so, what to use?
Ducmonsta
I'll play. Rigid 40" combo, 2x 6"SR2 driving amber, 8x Dually (2x diffused, 2x amber spot, 4x white spot)
What can I say? I'm like a raccoon!
kojackJKU
Autism Family Travellers!
Try rain x or a similar product. I have to do my lights with it this year to keep road grime to a min.
XJLI
42" Olympus Pro Series combo beam up top, 14" Olympus single row painted with duplicolor metal cast on the brush guard
D45
I need to figure out a sweet spot for aim my 30" bar
Any tips of trick on aiming these?
I want the most usable coverage of course
AFBronco235
Crew Chief
Check your local laws. Some states have termination ranges that the light must be focused on to be legal for on road use. For Indiana, I believe its 500 ft. How high up is your light bar mounted? With some simple trigonometry, you can figure out what point to aim at on a wall 50 ft away to get the aim right.
D45
Not sure the overall height, it is mounted on top of the bumper
V45W_Proto2.5
