Onboard Air picture thread. Show off your OBA systems
v_man
To run air tools like a ratchet on the trail , you're gonna want at least 5 cfm pushing them . It's going to be hard to find a 12v electric compressor that will get you 5 cfm ... This dual ARB is rated for 6cfm , but it's also over $500...
You really do want 100% duty cycle , anything less and you're going to be maxing it out and waiting for it to cool off ...
LandCruiserPhil
It depend on your needs and expectations. I can loosen (105ft/lbs) all 6 of my lugs,then remove them without waiting using an IR 3/8" gun and a PUMA. PUMA has no duty and can run for hours. You are 100% correct if you are trying run tools continuous but if that is you intent no 12v is not going to live up to your needs.
rabies
time is running out.....
seen it before but not lately. i wonder to see more bumpers used as air tanks :D
Rogue
Zombie Response Team Lead
Those of you running the pumps under the truck, aren't you worried about water intrusion?
The intended use for my OBA setup is to air my tires back up after wheeling... plus adding an air horn for LOLs. It will also run my front locker when I get one. Mostly, I just don't wanna get stuck in the middle of nowhere without air.
I'm definitely not going to run air tools a lot.
I may sell my Viair to some kid with air-ride on his civic and get a better compressor. I didn't know any better when I bought this one. :p
D45
How many amps do those PUMA's pull?
I installed a Gall's fused 3 port accessory on the bed cap rail......but I think its only 20AMP rated
I wired the 3 hole box with 10g wire
I could either tie into the wiring for the 3 outlet box, or solder in a cigarette lighter plug into the Puma wiring?
I was thinking about mounting on the side shelf next to my tool chest
Whats EP say?
D45
I just found the info....the PUMA mini pulls 30 amps
Anyone running that Smittybilt 2781? Looks impressive for the specs and the price
But I just found that one pulls 45 amps!
The 20003 Viair compressor and tank combo kits look nice and they are around $200
http://www.ebay.com/itm/VIAIR-20003...Parts_Accessories&hash=item414eee50e2&vxp=mtr
VIAIR 275c Compressor (27520)
120psi (25% Duty)
12 volt Permanent Magnetic Motor.
Max Working Pressure of 150psi.
18 Amp Draw
1.5 Gallon Tank
The Viair 20005 tank and compressor combo are $20 more and you get a 2 gallon tank
http://www.ebay.com/itm/Viair-20005...Parts_Accessories&hash=item4171f87205&vxp=mtr
2 Gallon Viair Air Tank
Viair 280c Air Compressor
110/145 PSI Pressure Switch
1/4" 175 PSI Safety Blow Off
Air Source Kit Compressor
Voltage: 12 volts
Max Amperage: 16 amps
Max Duty Cycle: 30% @ 100 PSI
Max Working Pressure: 150 PSI
kojackJKU
Autism Family Travellers!
120psi (25% Duty)
18 Amp Draw
1.5 Gallon Tank
Voltage: 12 volts
I am going to be trying the smittybilt compressor after Christmas. Along with a bunch of their products. The dealer is a business associate and im getting a good deal on the parts. I know that very soon after I will have to powdercoat the bumpers and stuff. I am a powder coater by trade so Its probably going to be done before they get installed. But im going with atlas bumpers and rockerguards all around. Plus all their little trail goodies as well.
highdesertranger
well I used to have a viair 550c. but it just didn't cut it. you know viair states you are supposed to have your engine running while using their compressor's. so I figured if I had to have my engine running why not just do this.
wow what a difference no comparison. highdesertranger
Rogue
Do these engine-driven compressors have a clutch? or do they run 100% of the time the engine is running?
zhukoveli
