Radio install help
jhill15
Hey guys im getting ready to order a new head unit of my 03 limited so I thought I would get a jump start and pull the old one out to see whats involved before ordering. I noticed that the antenna has 2 cables instead of 1 like in most vehicles, im assuming one is to power the mast and the other is for signal. Heres a pic
the aftermarket harness doesnt show a spliter for the atenna so im not sure if I need another harness to make this thing work or not. Heres a pic of the harness
It the metra 70-7003
Also is this the only harness I need for the intall, does the amp power all the speakers etc...
bikerjosh
Actually there are two different antennas, I only hooked up the front when I was installing mine. I used the wiring harness you have pictured above. If you have the "Infinity System" make sure your replacement deck has the same number of preamp outputs. My 98' needed a deck w/2 sets versus the normal one.
Hope that helps
jhill15
What is the 2nd antenna for? Yeah I went back and checked to make sure the radio had two pre amp outs. Heres the two im gonna torn between
im pretty sure im gonna go with the jvc, but the pioneer keeps catching my eye and luckly the previous owner did all the hard work of switching the climate control underneath so I wont have to fool with it
And this definitely helps, thanks man!
jhill15
I ended up ordering the jvc. It should be here hopefully by next Saturday but because of the holiday it might be here monday. I will post back on my semi-build thread. Thanks for the help bikerjosh!
bikerjosh
To answer your question the second antenna is in the rear window, I think. Didn't notice a difference w/without it. I added a inline switch for the antenna so I could keep it down while offroad and still have the radio on.
jhill15
Nice, my atenna is broken so im gonna have to replace the mast, although I thought about mounting a fixed antenna and just un plugging the power antenna at the motor but im sure if that will mess other things up.
Inyo_man
Don't piss down my back and tell me it's raining.
My rig suffered from a broken mast as well. I replaced it with the same, but also installed a switch to control when it's up or down.
Installing a fixed mast and unplugging the power source to the motor is not a problem.
MascotRejct
So when you were looking in there, how hard did it look to move the climate control down below? I'm thinking i might do that sometime soon. I believe the auto climate control is just electrical connections, yea?
jhill15
Inyo, im definitely look into doing a fixed antenna, I think now the only issue would be removing the actual power antenna from the fender and attaching the fixed in its place im not sure if the hole in the fender will be too big or small, just something i'd have to figure out when actually swapping it out.
Mascot, i think it would be very easy to switch the climate controls, lucky for me it had already been done but I did sneak a peek at what it looked like and theres just 4 screws and 2 brackets identical to the factory stereo, also theres no divider between the units its pretty much just one big hole when you open it up
this was a pic I took of the stereo harness but you can see the climate control below it . Heres a vid I found on how to do it How to Remove DVD Player from 2004 Mitsubishi Mon…: http://youtu.be/-g75eQjmjXw hope that helps man
Clemtiger84
