TerraLiner:12 m Globally Mobile Beach House/Class-A Crossover w 6x6 Hybrid Drivetrain
Haf-E
In other words - there are lots of options...
Yes - I agree completely.
On the subject of "portal" axles - they are mostly used with smaller vehicles with smaller tires in order to gain the additional clearance to allow them to travel in the ruts left by the larger trucks - so, for a rig as large as the proposed Terraliner - I would think conventional axles (with hub reduction gearing perhaps) would be enough for "bad road" use - especially if some type of air suspension was used to improve body/frame clearance when required. I think the desing will use something like 20" rims and 40" tall tires - similar to what a MAN or Tatra chassis uses.
thjakits
Heh. I knew what the Eleganza was called.
HEHE!!
The point I was making in the last couple of posts, was there is more than one way to skin a cat. I wasn't recommending a horse buggy suspension for an ExPo truck, or recommending the Eleganza setup - but simply illustrating the point that there are lots of different suspension systems.
You are right!!
I made a similar statement a few pages back about a HPV (tadpole trike with air-suspension and a unique front suspension) - check it out:
Unique front-suspension:
http://www.autospeed.com/cms/article.html?&A=111098
Air/water suspension:
http://www.autospeed.com/cms/article.html?&title=Chalky-Part-9&A=111868
Previous iterations with more conventional suspension systems:
http://www.autospeed.com/A_111091/hDg34uLtp_1/cms/article.html
Design Overview:
http://www.autospeed.com/A_111092/hDg34uLtp_1/cms/article.html
WARNING! This site is highly addictive!! ...you have been warned!
Basically he shows that what works for one vehicle, doesn't necessarily work well for another....!
I agree there is many ways to skin a cat - however by now we have fairly well defined what Terraliner needs to be able to do.
From that set of requirments, I would say what Haf-E posted pretty much nails it.
The shown hendrickson suspension is a trailer version and a rather expensive one! [But seems to work well!]
Again - Bio's emphasis is on inventing an art master piece that also works the intended purpose.
Whatever is underneath (below the truck body...) maybe "art" for you and me (and sometimes technical solutions seem to be art - in the way an elegant solution is found over a rough one), but I doubt that I would let any "Art Deco" or "PostModernism" .....whatever either is..., interfere with solid functionality!
I believe neither does Bio - so all we need is a solid, sturdy, simple solution, for the limited OFF-road capability required - ....and one that can provide a smooth/soft ride.
No need to re-invent that - it is already there!! Enough work to do to adapt the system properly to the rig at hand.
We are not looking at a "on the edge extreme" machine, that would require a complete rethinking of suspension-systems.
Requirements are rather benign over all - though the end-result still will look rather tough!
Trailing arm suspensions work a treat on off-road trailers, not so much on driven axles - lots of torque reactions there....
Just roam through a few 4x4, off-road, rally - forums and look at the various suspension iterations - everyone comes back quickly to fairly the same concept for a specific application.....
Obviously you could try to come up with something new - however if so it should have at least one advantage over the status quo, WITHOUT incuring any deficit to the same. E.g. for the present application I don't see any advatage of an IS vs a SA (to the contrary, I see quite a few deficits for the IS).
Would we be discussing a Rally Truck proposal - there certainly would be a tough discussion about IS vs. SA and with good reasons - but the requirements would be a completely different set!!
thjakits:coffee:
dwh
Tail-End Charlie
Actually, that Hendrickson in the link I posted is not a trailer suspension. Look at the video on that page and you can clearly see that the axles have differentials.
There is no re-thinking of suspension systems needed. They already exist. What is needed is to decide which would work well with electrical drive hubs on a big heavy truck - that is if biotect should decide to go with drive hubs. If he goes with one drive motor per axle, then it's a different story.
But assuming electric drive hubs, then it *will* be IS.
Okay, so then it becomes a question of *which* IS suspension - trailing link, walking beam, double wishbone, etc.
Here's the Hendrickson page for Bus/RV/Medium Duty:
http://www.hendrickson-intl.com/Truck/Bus-RV-Medium-Duty
Just about any of those could be fairly easily modified to be used without a live axle in between, and would work well for a hub driven IS.
I rather like this one from their Fire/Rescue page:
http://www.hendrickson-intl.com/Truck/Fire-Rescue/FIREMAAX-EX
I could see that being used with drive hubs as an IS.
They even have a hydro-pneumatic system on their Military page:
http://www.hendrickson-intl.com/Truck/Military/HHP-System
There's nothing at all exotic about these things - these are all "off the shelf" suspensions. True, they'll need mods to work as IS and to use drive hubs, but otherwise, it's all just standard stuff.
thjakits
you are right - my mistake!
And that is because???
Whether central motor and full axle or hub motors - the suspension system has NOTHING to do with it.
WHY do you think a hub motor HAS to have a IS?
For the application at hand - IS has only negatives and not a single advantage over SA (...in my book).
With hub-motors (if similar to the one shown from the electric racer), you can put them right INTO the axle-tube at each hub....
The question of SA vs. IS has NOTHING to do with if you use hub motors or shaft drive....
Cheers,
thjakits :coffee:
optimusprime
Proffessional daydreamer.
Bio
I think you are going to have to start making descisions soon,otherwise there is a danger of this thread really spiraling out of context.
As i have mentioned before, we need a retrospective of where we are now,what has been decided and what the next 'item' to be decided will be...
So far we know that : it will be of a 'space frame' tubular design.it will be 6x6 and thats about it...
So we need to choose ...
Drivetrain, hub motor,tradition axle/ shaft,portals.
Suspension,independant, leaf,coil,air,hydraulic,hydro pneumatic.
Powerplant,diesel,diesel electric,jet turbine,warp reactor.
This will then get us to a stage where we can say we have a 'rolling' chassis design,we know what we NEED to be able to get this vehicle moving,so now we can design the rest of the vehicle round it!
thjakits
Bio
OPTIMUSP
Damn - I DO like the WE part in this!!:coffeedrink:
thjakits :bike_rider:
optimusprime
OPTIMUSP
Well i've tried to be inclusive,make eveyone feel special!
Besides if it all goes wrong,we can always blame the designer .....................:Wow1: :coffeedrink: ( sorry Bio)
biotect
Designer
Bio
Hi optimus,
Gosh, that was a positive firestorm of engineering discussion! I will respond in item-by-item detail in my next post, which I hope to get on the thread before 10 more engineering posts appear....:sombrero:
In short order:
(1) Straight-Axle versus IS.
I find myself being convinced in favor of straight axles, and no IS. Haf-E seems to be deciding in favor of straight axles, too, and this is an overlanding vehicle. So the complexity entailed by IS seems a potential problem, and campo is perhaps only interested in IS because he currently has leaf springs, and wants a smoother ride. According to all, straight axles can deliver that smoother ride, with coil/air suspension.
So unless I hear some really convincing counter-arguments soon from NeverEnough and campo, as to why IS is still preferred to straight axle, that's where I am now headed. thjakits has made a really good case for straight-axle; I need the other side to make a really good, summary, point-form case for IS. The TerraLiner will be a serial hybrid (more on that below), so as even thjakits admits, in the serial hybrid scenario perhaps IS might make sense because it might allow a long, uninterrupted space in the center of the truck. But even in IS, the links in the suspension function better when long, so one probably won't gain that much uninterrupted space in the center of the vehicle in any case. Sounds like a good enough argument to me.....:ylsmoke:
(2) PowerTrain
Sorry, dwh, but microturbines are out, at least for now.
My engineering friends and I have been designing the space for the motor/generator so that it could accommodate a pair of Capstone C65's, if necessary; and a slide-out tray that could take the weight. A while back someone (I forget who) advised me to design a generator compartment in such a way that the motor/generator could be easily swapped as technology advances. That's what I am doing.
As present, I am leaning in the direction of a Jepotnik-sized diesel engine and generator, 3.2 L, 182 HP, 6 cylinder, with 120 KW of electrical output – see post #673 at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page68 . But the Oshkosh 4x4 L-ATV used in Baja had a a 400hp 6.6L Duramax engine, so who knows? And the Oshkosh L-ATV is a much smaller vehicle than the TerraLiner, just a 4x4 – see posts #671 to #673, at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page68 .
So I am erring on the side of caution, and designing the engine compartment to accommodate an engine/generator even as large as the 750 HP Volvo F16 – see http://www.google.co.uk/url?sa=t&rc...-l1GMOG4L_L0DOaVzgK9oyg&bvm=bv.82001339,d.bGQ and http://www.volvotrucks.com/trucks/u.../key-features/Pages/volvo-diesel-engines.aspx . Or something like that. Sure, this may be complete overkill, and totally unnecessary. But until someone does a convincing power calculation, the size of the engine compartment will have to remain a bit vague.
Think of the TerraLiner as a motorhome version of the Abrams Tank: a completely modular design, so that the TerraLiner's mechanical and electrical elements could be easily rebuilt and/or replaced, as technology advances – see post #516 at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page52 , and see http://channel.nationalgeographic.com/channel/ultimate-factories/videos/abrams-tank/ :
[video=youtube;dG4CLaBMfVU]https://www.youtube.com/watch?v=dG4CLaBMfVU [/video]
The United States has not built a completely new Abrams tank from scratch since 1993.
(3) Power Calculation
The power calculation should be easy enough to do, one would think, at least for a trained electrical engineer (Haf-E?). The TerraLiner will be a full serial hybrid, not parallel; with 6 separate electric hub motors, as per Haf-E's recommendation. It will be 10 m long, and 20 tons, so just stipulate a power size for the electric hub motors, and the power requirement of the generator should be easy enough to calculate?
Sure, batteries in between could lower the necessary generator size, the batteries draining a bit faster than they charge, thereby making a small diesel engine/generator possible. That's the basic principle behind the "range extender" format: that the batteries allow a significant reduction in the size and power output of the generator. But it would be good to begin with an “extreme case” scenario: no batteries at all, just the diesel engine + generator, directly powering the hub motors, as per the PistenBully 600 E+ snow groomer shown earlier – see posts #934 to #939, at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page94 . Recall that the current model of the Pisten Bully 600 E+ has no batteries; these will only be added in later models.
And after this "no batteries" calculation, then throw batteries into the mix.....
(4) Supplementary 20 KW generator.
The TerraLiner will also carry a supplementary 20 KW turbocharged generator. But not to act as "backup" for the main engine-generator. But rather, to charge the batteries efficiently and quietly when parked, as suggested earlier in the thread.
(5) No Portals.
Last but not least, no portals. The TerraLiner will be big enough, and its tires big enough, that portals are another unnecessary complication. The TerraLiner is a 6x6, so the largest inter-axle distance will be much smaller than any of the commercial overlanding vehicles posted a while back. And its breakover, approach, and departure angles will all be much better, even with the second and third axles clustered in back.
Think of it this way. I will want side-lockers between the first and second axles, of the kind pictured in these images of Zetros trucks:
In a standard staight-axle configuration with XZL tires, the center of the tire is either 58 cm (14.00R20) or 61 cm (16.00R20) above the ground. At least theoretically. When under load, or when deliberately deflated, it will of course be less. This then suggests that side-lockers could descend as low as just 80 cm above grade on either side, between the first and second axles, without significantly impairing the inter-axle breakover angle. In the following schematics of MAN-KAT 6x6s, the "peak" of the breakover angle between the first and second axles, seems no better than 80 cm above grade; not much higher than the wheel centers:
So if one wants side-lockers that can descend on either side to 80 cm above grade, then the only thing that portals might add, is an additional 20 cm of clearance, because the straight axles across the vehicle could now locate at 80 cm above grade, instead of 60 cm. That additional clearance may be important in a mog-sized vehicle that wants to rock-crawl off-road. But would it really be important in a bad-road expedition motorhome? I'd like to hear the argument that the additional complication of portals is really worth it, in a vehicle the size of the TerraLiner.
More on the topic of comparative breakover angles anon.
Hope that clarifies matters, for now.....:)
All best wishes,
Biotect
PS -- Personally, I really enjoy reading the engineering banter, even when it gets a bit chaotic and out of control. I am not an engineer, so this banter always provides enlightening information, at least for me. After all, I created the thread precisely so that I could get practical, engineering, and overlanding advice / feedback for an innovative transportation design exercise. I can do the design; but it's great to learn that I should be designing a vehicle that includes a truck-sized "rock-slider".
On that topic: optimusprime, many thanks for the pictures of rock-sliders. Would you know of any good videos that show rock-sliders in action with SUVs?
optimusprime
F
Hi optimus,
(5) No Portals.
View attachment 262565 View attachment 262566
View attachment 262567 View attachment 262568
All best wishes,
Biotect
In that case, would not using air suspension be beneficial to raising the body higher, giving just thst extra bit of ground clearence for the side lockers?
Haf-E
I agree with the direction you are going - it all sounds good - except - I think the question of 6 individual hub motors without differentials versus 3 separate motors with traditional straight axles with differentials is still open for discussion. This can be done separately from the discussion of suspension to a degree - but the hub motors will increase the unsprung weight significantly so that would need to be considered. Also the concern of how the hub motors will handle water crossings and sand as well as how they accommodate the brakes - including parking / emergency brakes.
There are some websites which have calculators for both EV and Hybrid configurations that will give you the performance for proposed vehicles with a specified electric motor rating, battery size and engine size and frontal area & drag coefficient - not sure if they allow for a vehicle this large...
The only other comment is on the sliders - with the storage boxes along each side the bottoms of them become the sliders - so they just need to be built strong enough to allow for that.
biotect
Designer
Wow,
Again, that was a virtual “firestorm” of engineering debate!
There was so much material, that it seemed best to respond in point-form format......
(1) optimusprime and thjakits: many thanks for all the additional info and images/videos for rock-sliders. Really, really helpful. In a conventional chassis, where side storage lockers are “hung” from above, sort of dangling between the second and third axle, dwh's point would apply: adding an additional tube or plate underneath them to carry the weight of the whole vehicle would be an impossible engineering challenge.
But the TerraLiner chassis is a tubular space-frame design created from scratch, with the side-lockers “fitted” into what is already a structurally load-bearing lattice. So now that me and my friends know about the desirability of “rock sliders”, it's just a matter of engineering the space frame to make these structurally possible. Of course, the actual plates would bolt on, and would be replaceable. But they would bolt on to a tubular space frame that could support the truck's weight at this point of contact, should it occur.
Really nice bit of engineering/practical detail, that. Again, thanks. But we'll see how the calculations work out, and whether the extra weight and load-bearing structure would be worth it. As both of you have also suggested, replaceable skid-plates might be good enough after all.
(2) dwh: you are right about the Orangewerk vehicle. Just fancy brushguards. But I thought that the format of the pipework above the cab to lift away errant hanging powerlines seemed especially effective.
(3) dwh: thanks for the image of the gopher pole!
(4) Outrigger stabilizing jacks: more on these in a later post, when I discuss the TerraLiner pop-up.
(5) Access stairways: thjakits, I am way ahead of you. I have a monster-sized file of webpages and images of all the possible makes and brands of scissor-stairways for RVs that you could possibly think of. Including “out of the box” foldable stairways and gangplanks made by various marine suppliers.
But I still think the Foremost Terrabus' access stairway is super-cool:
brewster_540-2.jpg foremost-terra-bus-h.jpg Athabasca_Glacier,_Jasper_National_Park_(7800640746).jpg
(6) De Dion Tubes.
thjakits, you are a wealth of engineering ideas. You are quite right, with electric hub motors, one on each wheel, “dead” De Dion axles might make sense – see http://en.wikipedia.org/wiki/De_Dion_tube , http://www.autozine.org/technical_school/suspension/tech_suspension1.htm , http://www.motorsportmagazine.com/archive/article/april-2001/89/de-dion-axle , http://www.locostbuilders.co.uk/viewthread.php?tid=82016 , http://www.pistonheads.com/gassing/topic.asp?t=867274 , https://www.google.co.uk/search?q=d...=X&ei=CbOhVNDVKIipOoDCgegB&sqi=2&ved=0CCcQsAQ
And so perhaps specifically engineered (i.e. non-Unimog) heavy-vehicle portals might be worth considering after all….?
(7) That video of the assembly process of the Grimsel race-car with 4 electric hub motors is one of the coolest computer-graphics demos I have ever seen. Worth posting again:
CONTINUED IN NEXT POST
biotect
Designer
CONTINUED FROM PREVIOUS POST
(8) thjakits, thanks for addressing the power requirements in detail:
A word to your power requirements:
I know Camo wants 500hp for his rig!! I tell you that is WAY TOO much for a 2-axle rig!
You really will never NEED that power! Camo might feel the need, because of his auto/semi-auto set-up. That's one item I certainly DON'T like on a Explorer Rig. Perfect for Long Distance Road Transport, but in a OFFroad/DIRTroad situation I'd rather have personal control over ALL my power and ALL my gears!!
If you have 500hp available it is just too easy to guzzle fuel (no matter if your final drive is electric - if you use 450kw you need to provide it - be it directly form the Diesel engine or via a generator...) - also it is very easy to break something if you don't use the power properly!
Figure it out: WHAT is your possible longest, steepest, straight (or max speed - take 85-90 km/h) climb you imagine (something like the Brenner Pass between Austria/Italy or similar stuff in the Rockies or the Himalayas) - WHAT power do you need to accelerate to and maintain that speed at MVGW with an additional 30 kt headwind/rain and pulling your trailer with your favorite toys anywhere on that slope? THAT's the max CONTINOUS power you need.....
A 42-ton 18-wheeler will not need the 500-600 hp they got today to maintain that - why would you at 1/2 the weight??
A 300KW power unit with a serious battery bank and 420KW capability on the wheels should make you a POWER-house/macho Truck amongst all of them out there!! ...and this unit should be efficient enough down at the max level you can pump into the battery bank when charging only....
Then some say: "You can have enough power, but never too much!!"
So six 70 KW electric motors, and a 300 KW electrical generator. Or did you mean a 400 hp diesel motor? Either way, it's still a good deal larger than a Jepotnik generator, whose diesel motor is 182 hp and produces 120 KW.
That's good to know, and I will try to determine the volumetric consequences for the engine compartment size.
(9) Slight correction. Haf-E, I thought you were advocating 6 individual hub motors! My apologies.
What you then wrote about the desirability of 3 e-motors driving still-quite-conventional locking differentials and single axles makes a great deal of sense:
On the topic of electric drive - I still believe that using one electric motor for each axle with a conventional driveshaft from the e-motor to the axle is the best solution - it allows the most redundancy and simplest yet most rugged design. With locking differentials in the axles the entire motor torque would be available on a single wheel - something not possible with individual hub motors. Using independent suspension would be challenging with the amount of torque available from a e-motor as the axle CVs would need to handle that torque.
Using conventional solid axles connected to the e-motors with standard drive shafts/u-joints also allows the motors to be tucked up high into the chassis - up out of the dirt, dust, water etc. If a motor fails the driveshaft could be pulled from it until it could be repaired / replaced.
And so too your follow-up comment:
So would you agree with thjakits' rough power calculation? In your configuration, using thjakits overall figure of 420 KW, the three e-motors would be 140 KW each (or roughly 400 hp).
(10) As for needing to convince bio, he is thoroughly convinced!!:
For the ultimate Serial Hybrid Ruggedness: 3x Solid Axles (portal or not) with switchable Lockers and a single big chunk e-motor/generator for each axle - and we are back at the Oshkosh power unit!!
Now we need to convince Bio, that there is really nothing to "Art Deco" under the rig!!
And thjakits, you beautifully summarized the current state of play when you wrote:
From that set of requirments, I would say what Haf-E posted pretty much nails it……
My sentiments exactly. That is precisely why I spent so much time earlier in the thread trying to “think through” the intended purpose and roads that the TerraLiner will actually traverse. In these ExPo forums one suspects that there is a tendency sometimes to get almost too enthusiastic about the technologies that spin off from rally racing, or the kinds of technologies needed for extreme off-road travel, or rock-crawling.
But what does a rock-crawling Unimog have to do with the TerraLiner? Albeit a very small “mini-mog” carried inside an Oshkosh trailer towed behind might come in handy…..:)
biotect
Designer
(11) dwh: many thanks for the links to the Hendrickson pages http://www.hendrickson-intl.com/Truck/Bus-RV-Medium-Duty , http://www.hendrickson-intl.com/Truck/Fire-Rescue/FIREMAAX-EX , and http://www.hendrickson-intl.com/Truck/Military/HHP-System . Thought I would post the pages of the pdfs, as well as the video:
This information on Independent Suspension alternatives is invaluable, and the second pdf nicely summarizes the possibilities for more demanding applications. As you know, I am strongly inclining towards Haf-E's proposed straight-axle solution. At this stage, I would need a lot of convincing to reconsider IS.
(12) optimus: excellent insight when you wrote:
Now we are not saying the Terraliner will be rock crawling, but if a 'bad rd' turns into 'no road' for some reason, you may need to drive off rd just to turn around.
All best wishes,
Biotect
