SETO - the DR(D4-7R) Moto
Overland Hadley
on a journey
Probably do. Not sure what good they're doing. They tire guy us used to use always takes them off and starts fresh when he would change my tires.
I read somewhere that moto tires are so well made that balance for one tire is probably pretty close for other tires. I guess that would be balancing for the wheel, more than the tire? I'duno, just reading and trying to learn.
I do know one thing, I look forward to summer when I can ride and learn.
Overland Hadley
on a journey
Should I carry a spare chain?
When out on a longer trip, something like the UTBDR or IDBDR, should I carry a spare chain? Or is a well maintained chain very unlikely to have a failure.
Also, if anybody can give me an idea of spares to carry that would be great. I know that it is a personal thing, but I do not want to be stupid by not carrying something. Keep in mind that I want to keep things light weight, while not being dumbly unprepared.
Thanks!
NothingClever
A good chain is unlikely to fail although you might want to secure your master link with dabs of Permatex on the pins or by S-wrapping a paper clip or appropriately gauged wire around the pins with some needle nose pliers.
Overland Hadley
on a journey
Thanks for the info. I am going to use an EK chain, got a good deal on an X ring. Will try their screw connector, so no clip master link.
Overland Hadley
on a journey
I know it is not an ideal place to put the weight of a gallon of gas, too far back and up high, but I decided to go ahead and mount a RotoPax on top of my rear Pelican case. I would like to have RotoPax mounts on my Wolfman racks and I kind of wish I had done some welded plates for the mounts before I put them on. Maybe the racks will have to come off next winter to have that work done. Anyway, on to the mount done today.
The RotoPax Deluxe mount on the Pelican
Used the included extra mount bracket as a mega washer on the inside. This thing is not going anywhere, dancing strong.
The 1 gallon can fits nicely on the 1450 Pelican.
Overland Hadley
on a journey
Winter Does Not Seem So Bad
Thanks to ProCycle for putting together such great DR650 parts!
Although the sub-zero (*F) highs still hurt, at least there is some fun to be had. Summer will come at some point....
Overland Hadley
on a journey
This is why I got my moto.
My extended family is worried about the dangers of me riding a motorcycle. And I am also very aware of the added risk that it brings. But it is something that brings me back to the freedom of being a kid, and that is worth the added risk in my life.
Overland Hadley
on a journey
Started working with the pile of new parts. Not in a big hurry to get it all done, just enjoying doing a little now and then.
Pulled out the new brake lever. This thing is truly beautiful, Warp9 makes exceptional stuff.
The Warp9 levers are adjustable, so now I can be snobby with my easy to grab leavers. Once the lever was installed I put on the new Double Take mirror. Getting better mirrors were a must for me as I could hardly see past my shoulders with the stock setup. Hard to be a defensive driver with poor mirrors. So no more scaring myself with surprise vehicles from behind!
Thats all for today, more tomorrow or the next day.
ober27
I wish bikes came from the factory with decent mirrors. Every bike I've ever ridden had me leaning one way to see past opposite shoulder.
Overland Hadley
on a journey
Replaced the carburetors secondary air filter.
This is what happens if the factory (1/8th inch dry foam) filter fails. No good.
Lets put a proper air filter on it.
Overland Hadley
on a journey
Changed the bottom chain roller to a bearing roller, instead of the factory spinning piece of plastic. Should make it a bit quieter.
(new roller on the left)
Also put a little button bolt where the top chain roller goes. People have had the top chain roller rip itself out of the frame, and there seems to be no problem removing it completely, so it is deleted.
Overland Hadley
on a journey
I wanted to quote this in my thread. It has some good info for outfitting a DR650 for long distance solo travel.
Original thread, Deep Desert set up. Self supporting adventures.
Fullyoffchop55 writes,
My bike is set up for deep desert solo riding. I think I have been through the whole thing over the years and upgraded the bike to perform and be adequately protected for sand, rock, single trails in the harshest conditions while being self supporting hundreds of kilometers from the nearest ….place.
I recently brought a new one, rode straight home to the garage and proceeded to strip it down and swap all my after market equipment from my old bike (28,000km) to the new one 8km.
Needless to say the old bike came up quite well with new looking bits and pieces on it. The new bike looked a bit rough and ready, however, it had all the goods and new components. Anyway here's is what I have done and found works well:
• Extra Heavy Duty tubes (not super heavy duty)
• Heidenau Scout K60 tyres front and rear – tried all the rest, knobs etc, this is the absolute best compromise for grip dry and wet and longevity. If I determine I am going to spend a lot of time in sand and mud I may put a knobby on the front
• Race Tech cartridge emulators in front forks
• Race tech springs in front forks
• Vince Strang Motorcycles (VSM) graded rear spring
• Renthal bars
• Trimmed ends off clutch and brake levers, better fit in Bark buster guards. (spare clutch lever is cable tied on)
• Bark Buster hand and lever protectors
• Rental gel grips
• Handle bar riser kit
• C-Tek 12volt charger cable wired in –
• Pro-Tech 12 volt outlet wired - in charge iphone, run air comp., charge ipod etc.
• IMS 20 litre tank (not convinced that the Safari 32 litre tanks are the go after some incidents with friends riding with me had these and stacked. I believe it unbalances the bike putting to much weight up front)
• Pingel fuel petlock
• Oil Cooler guard (made myself out of detention screen material)
• Armor plate cover guards – 3 X – stator, gear change side, clutch brake side, and oil filter cover
• Sump protector – B&B
• Pivot pegs
• Two Brothers exhaust
• SW Motech centre stand
• Shortened side stand, camel toe on end of stand
• Lower bike -Lowest link on shocky, drop forks 30mm through triple clamp.
• 44 tooth rear sprocket
• De-beaver back end with a VSM rear tidy and plate LED kit
• K&N air filter with foam cover (and carry spare foam cover).
• K&N breather filter
• Oil filter magnet
• Throttle lock (Twisted rubber coated coathanger, works perfect)
• Reinforced aluminum brace for front fender
• Disconnect - side stand cut off switch and clutch cut off switch
• Change all Phillips screw heads to stainless Allen key heads
• Fit Headlight off/ on switch (cold starts in desert not dragging on power supply)
• B&B rear rack
• Wolfman rear pannier racks
And luggage carriers:
• Wolfman roll top panniers
• Wolfman Expedition roll top medium duffle bag.
• Wolfman enduro bag
• Wolfman Tank bag
• Wolfman fender bag (out on the Gary “Highway” somewhere if anybody finds it.)
Love the Wolfman gear. Have abused mine for years in the desert and its still going strong.
Oh yea, I don't ride any bike including my DR without my small cruiser Airhawk. Thank you for this invention!
I carry my excess long reach fuel in 2 X 10 litre and 1 X 5 litre fuel bladders for extreme reaches that roll up snug and small when I don't need them.
Speaking of fuel I have read quite a bit about guys re-jetting and squeezing an extra couple of pony's out of the ‘ol DR. This comes at a cost of drinking more fuel. I wouldn't dare, one of the biggest hurdles of self-supporting desert riding is fuel (and carrying extra). For me the DR with a 44 tooth rear sprocket has more than enough torque to pull me out of trouble off-road and fly along way above the speed limit when on open road.
I try and carry mainly freeze dried food and use a Jetboil stove (check them out, just the best technology in camping) to heat water for food and cuppa.
I carry ~ 4 litres of water on the long stretches in a bladder style container.
The spares and things is exhaustive but I carry about 500ml of oil, small chain breaker links and master links, puncture repair, small length of fuel hose, tie wire, electrical wire, gaffa tape, rescue tape, Tyre Pliers bead breaker and set of tyre levers (spoons), small 12v air compressor, a selection of nuts and bolts that suit, and a selection of super strong zip ties. I guess there are more bits and pieces I need to look at to remember,(e.g. spare tube, extra tools, etc.)
My home on the road consists of a super light (Northface Bullfrog) 2 man tent, a small 38mm thermarest self inflating mat, a really excellent down sleeping bag, Blackwolf self inflating pillow and a small light 3 leg stool that rolls down into a small package.
All this sounds like a lot when you write it down but it packs down quite small and doesn't really represent exorbitant weight. However, when you are in for a long reach of 700kms and more and you have 30litres of fuel and fluids on the back you could swear you were riding a GS1200.
My insurance being out in the middle of nowhere by myself is my Spot satellite messenger and tracker. This is a must and gives both myself and my family at home piece of mind.
Lastly about the DR, it's a bike I can pick up myself if/when it goes down. Its also easy to strip down and work on (uncomplicated ) when in the middle of nowhere.
Over 30K in desert riding over 2 bikes and I have never been let down.
Long live the DR650 the trusty little machine.
Overland Hadley
on a journey
Part of Winter II (or III) will be replacing the fuel tank and going with LED turn signals. And while that will not be happening for a year or two I went ahead and installed the relocation brackets so the blinkers will clear the larger fuel tank. The brackets make the front turn signals nicely tucked in and cleaner looking.
DanoWall
