What did you do to your Expo Jeep today?
dan0
Got stuck in a snow bank at my house. Then dug it out.
Went for a drive to a semi plowed boat ramp and drove around a bit in 2WD trying to get a feel for how capable it would be in 2WD.
Not much else today. It's going to be my daily for the next week or so as I do some work on my Audi (front controls arms, full coilover suspension, center diff fluid change)
Then the Jeep will get some attention. Driver's seat repair/replace, oil pressure sensor, finish cleaning up the mess from the heater core, some work on the cargo area, hitch (hopefully), roof rack, and the list goes on.
scramfan01
Pulled a UPS truck out of a snow bank he backed into. I didn't want to take a pic of his truck and get him in trouble, but here is what I winched him out with.
Mitch502
I work at the main Hub here in Louisville. Greatly appreciate you helping a Brother in Brown!
Jakes01234
So I was messing around in the snow and I turned on my front arb locker and my compressor would not stop running. When I was driving the arb just keeps dumping air. If I stop the jeep the air pressure increases. If I turn the front locker off there's no issue.
Any ideas?
jpat30
Finally was able to order a SpeedoDRD from 12 o clock labs; Now I can have an accurate speedo again:sombrero:
Lucky j
Any ideas?
Your saying that your ARB locker systeme only loose air when it is engaged and the truck is moving? It need to be look into.
oskarf150
