2006 1st-Gen Tundra Doublecab Build
FJR Colorado
Table
I was looking at very nice stainless steel tables and other tables designed for expo travel. There are some nice options out there but pricey.
I wanted to do something inexpensive that leveraged my existing infrastructure. I came up with this...
It's a 4' piece of laminated pine board with a lip built in to firmly attach to the overhang piece of the Unicover topper. A single 1/4" x 20 bolt with a knob is in one corner. The leg is a monopod for a camera. I used a furniture piece to make a 1/4" x 20 nut attached to the underside. It's light, easily transportable and strong. Most camera tripods would also work for this purpose.
Next up, I have a home-brew awning in the works. I basically have it done but we are getting lots of snow which makes setting it up a tad impractical.
Happy New Year to all ye Tundrabirds!
FJR Colorado
Home Brew Awning
So I worked up an awning over the winter and today I tested it out for the first time...
It works out well, is light and is not too difficult to set up.
rickashay
Wow that is a great camp setup seeing it all up and running. Perfect adventure rig right here, well done.
toyotech
Looking good. Main reason I want the ladder rack is to do an awning. But due to low garage door. I can't. Hopefully this new to me housing im working on buying will clear my truck with rack.
FJR Colorado
Thanks all for the comments.
I was looking at spending $400 on a fancy table. And then $800 or so on a nice awning. This may not be the most elegant thing but it's utilitarian and all it cost me was about $50 in various Home Depot stuff and some old parts laying around. Plus, I kinda' like things that are rigged up... I just do...
toyotech
It's not worth it to spend so much on an awning. Homemade is the way to go plus won't hurt as much if it gets damaged or stolen.
rambrush
Great job on the skid row skid plate!! I went with the whole set and boy are they heavy.. Had to shim mine a bit because I went with the 1" drop so my cv joint boots won't tear.
They make changing the oil filter pretty easy due to open access on the side.
FJR Colorado
Same here. I have a diff drop kit so the 1/2" spacers that ship with the unit weren't enough for clearance. I used a 1" steel spacer from Lowe's on the rear bolts. Later I found some nice 1" bushings at Ace Hardware which I will swap out since they are a bit beefier. I had to find some longer bolts as well.
Yes, very impressed with the quality of the Skid Row. I can see buying the whole set over time.
Yes, oil changes will be a breeze. They even give you the little peephole. Well-engineered.
FJR Colorado
Yellowstone Adventure
I took the Tundra on a 1,900+ plus through Yellowstone NP and the surrounding area. It performed perfectly. What a comfortable and reliable excursion rig. All those days wrenching sure paid off. It's now time to enjoy the ride!
Here is some home video:
https://vimeo.com/130747677
A little section on the Tundra starts at 22:50
JCMatthews
Tour Guide
I have to agree 1st gen Tundras are comfortable and reliable. We are at the +/- 4000 mile mark on our Alaska trip, and our Tundra has been a great excursion vehicle. I built a sleeping platform for it and will share pics when we get home.
JCMatthews
Tour Guide
I have to agree. We are at the +/- 4000 mile mark on our Alaska trip, and our Tundra has been great. I built a sleeping platform for it and will share pics when we get home.
jordanP13
