All-Purpose Scout 80 build
superbuickguy
That's a good one, you must of looked at my build. :) Still in the garage, but getting close. 4 years now so far.
*snicker* I did, but I skipped to the last chapter and said "but how does it do after years of use?" I'm concerned that the material is too hard and will delaminate with the heat cycles... but I don't know, thus, the questions.
Scrapdaddy
Superbuickguy,
To be honest, I've never heard any negative talk about either product. I poke around the hotrod forums, that use a lot of Lizard Skin and haven't read anything but good. I'll report back in a couple more years!
superbuickguy
excellent, between you and MotoDave, there will be a good real-world test. I'm far more involved in the hotrod world than I am in the 4x4 world (though, strangely, I like 4x4 far more than the cars)... What I'm really interested to see is if it delaminates or cracks so that water can get behind the media.
MotoDave
MotoDave,
I've been following a long with you, doing great! I used the Lizard Skin products on my FJ55, inside and out, in the doors, under hood and it really deadens the sound. Also used the LZ ceramic coating to cut down heat. The company doesn't recommend using their products as a bedliner, so I sprayed Monstaliner over it, black underneath and color tinted inside the interior. Both products work well together.
Keep up the good work!
Ron
Dang, I really like your build. I have a huge soft spot for FJ55's, I really would like to build one some day. The size of the body didnt really fit with what I want my truck to do but they are cool as all heck.
MotoDave
Well time for another long overdue update, this time I have a good excuse though :)
My wife and I had out first child, a healthy baby boy named Ethan. I took a month off of work, and I've managed to sneak some garage time in when the wife and baby are napping throughout the day.
I finished up work on the floors with the same lizardskin coating under the passenger compartment floor boards, as well as painting the frame where I am finished welding. The body is set back down on the frame and the truck is back to being a roller.
To finish off the floors I needed to fill in this gap I cut out to clear the transfer case.
Played with cardboard until I had a shape that I was happy with, then transferred the design to metal and used my buddy's brake at his house to make the bends.
First piece tacked in
The second (more complicated) piece didn't work out exactly like I planned, I didn't account for the metal shrinkage at the bend quite right, so I wounp up modifying it a bit but I'm still happy with how it came out. I still need to finish weld this in and grind it down smooth.
Next I cleaned up the transmission tunnel cover, opened up the shifter hole to fit the NV4500 shifter tower, and welded up the stock transfer case shifter hole. The transmission shifter is roughly in the same place as the stock one, but the t-case shifters will be quite a bit further back. I am still working out exact placement and will have to cut a new hole once I get that sorted out.
No more transfer case shifter hole. You can see i used a big piece of copper as a backer, really makes work like this pretty easy. I tig welded up the patch panel, makes for less weld to grind down after the fact.
Found a nice big Hurst shifter boot that covers the transmission shift tower, and the rest of the transmission and t-case fit nicely under the cover so I didn't have to modify it too much more.
To finalize t-case shifter location I wanted the seats to at least be mocked up into place. The seats I'm using are from a TJ Rubicon unlimited, and have a nice fold forward feature that should make getting into the back seat easier, so I wanted to keep the bases intact. This means cutting out the stock seat bases, and making some quickie mock up bases to let me play with height and position.
I'm going to cut out the bulkhead behind the seats, but I think with the seat flipped forward access won't be too bad, and I also can use the area behind/under the seat for storage.
Next steps - build some transfer case shifters & finish the floor mods, then pull the drivetrain for finish welding of more brackets on the frame, some firewall modification needed to clear the exhaust manifold, and pull the axles to finish weld the suspension brackets and re-gear. Then I'll actually be dropping the drivetrain back in for the (maybe) last time, and start plumbing and wiring.
rayra
...I'm going to spray a top coat on the lizardskin, I figure it can't hurt and will add some UV protection even though its underneath the truck. Leaning towards a machine grey for the reasons you mentioned, downside is it'll make any leaks painfully obvious. There's something to be said for satin black too :)
That's a Feature, not a detraction.
justcuz
Welcome to the club and Happy Fathers Day! My son is working but my daughter and I went to the Fathers Day Roadster show today in Pomona. She's 27 now, we had fun. Came home to fish tacos and beer! I have a great wife!
The Scout is looking good, great fabrication and thought going into the build.
I started our marriage with a pickup and a Jeep Cherokee. After baby number 2 (the girl) we moved up to a Suburban. My wife still drives a Suburban and we have not had a kid in the house for many years.
MotoDave
Looks like an engine change to an LS motor.
Ding ding, winner. I have a 5.3 out of a Silverado (LM7) on the way, which is really the motor I wanted in the first place. Since I started this project they have become a lot more available so I pulled the trigger. May as well build it how I really want to.
Now who wants a TBI 350? :)
Scrapdaddy
Great choice. I've got one in my FJ55 and just fired it up a couple days ago. Working on the exhaust now. Sure sounds good with open headers!
MotoDave
Funny I was just reading through your build thread (again) to find out what fuel pump, headers and engine mounts you used :)
xander69
