The Gen 2/2.5/3 horn button consists of a membrane switch in the steering wheel that commonly fails by getting stuck in the closed position. This ultimately leads to the horn being stuck on. When this happens the only way to turn the horn off is to pull the horn fuse in the fusebox or disconnect the electrical connectors to the horns under the hood.
The membrane switch is technically a non-servicable part as it is integrated into the airbag module. Because Mitsubishi doesn't wan't to incur any liability from people messing with the airbags, the only factory sanctioned way to fix the switch is to buy a new airbag module from the dealer for big money. Let's call that OPTION A.
Luckily, there are two other options...
OPTION B
As this video shows, you can VERY CAREFULLY open the airbag module and fix the switch.
OPTION C
Last, you can tap the horn circuit and wire up a new switch.That process goes like this:
Remove the lower steering column trim by loosening these 5 screws.
Once the lower trim is removed, the upper trim can be removed as well.
Find this connector to the right of the steering column.
The green/red striped wire is the horn circuit.
Tap into it however you like...
...and wire up a new horn switch wherever you like.
Now, you can honk to your heart's content!
OPTION B
OPTION C
