REVISED-1985 Toyota Land Cruiser BJ74 Frame Up Full Resto, LHD, Many Mods, CT
NoahTheMod
......now $35,000. needs to go to a good home!
Located in Connecticut. Shipping available.
Left Hand Drive
Approximately 200kms (128k miles)
13BT Turbo Diesel Engine
9.9/10 Perfect Condition, Mechanically
9.9/10 Perfect Condition, Interior/Exterior
Full Frame Up Restoration (2012-2014)
Upgrades/Mods:
ARB front bumper modified to work with the factory PTO winch.
Custom built 3/16" skid plate to protect the winch
Southeast Overland winch rope
JDM Land Cruiser yellow fog lights
Complete Ironman Suspension with greasable anti inversion shackles
FRP Fender Flares (imported from Australia)
Replaced all foam seals in the complete heating system, and all the vents
Powdercoated Frame, Wheel Housings, and all Exhaust Shields
New OEM Windshield glass and all new OEM seals on all glass
Underhood hardware yellow zinc plated
Repainted engine and everything under the hood
New OEM water pump and a new starter on the motor
Rebuilt injectors
New belts, hoses and all vacuum lines
All rewiring was done under hood and under the seats, nothing under the dash. This was done to make it easily serviced.
Fuse box in the correct place in the left kick panel.
Wire splices are soldered, taped and heat shrink applied. All wires placed in split looms.
Redarc 24V to 12V Tail Light, converted with 7 pin connector
Interior completely covered with Dynomat sound deadening.
Seats are original, and the interior is in almost perfect shape.
Newly replaced door panels—custom made vinyl similar to the original pattern, headliner, and the outside of the right front seat, as the vinyl had a crack.
ISSPRO EGT, Boost and Oil Pressure gauges
Wastegate boost controller installed under the hood. Max pressure is 14.
Newly Rebuilt A/C with New Factory Condenser
Fluid Film applied to the inside of all body panels.
All doors shut perfect, door, hood and fender gaps are all perfect. Not an air leak or rattle anywhere.
Many, many new OEM parts installed in the restoration. Too many to list! Every effort was made to keep as original as possible.
Newly rebuilt Alternator
OEM Steelies with new Toyo M/Ts in 285/55/R16
Extra Set of OEM wheels with tires
Located in Weston, Connecticut. Shipping available at buyer's expense.
Clean title in my name, ready to sell.
This is an immaculate turn-key restoration of an expedition-ready classic. Every detail has been lovingly attended to, and no expense was spared. Where OEM factory parts were possible, they were installed. Other aspects were added for better performance or utility.
There is no rust on body panels, frame or parts.
Has been getting 25 mpg on the highway, 20-22 mpg in city driving.
Drives perfectly, as it should. Starts effortlessly, as the factory glow plugs work perfectly.
Runs at 60 PSI oil pressure at warm, 40 PSI at idle.
Never taken off-road.
Contact me via PM or by email at brianphillips@gmail.com for more information.
DetroitDiesel
That is amazing. Truly amazing. Better than new. These are my dream trucks. Dream being the key word. Good luck making someone's bucket list happy.
mervo
Dang, I'd eat off the underneath of that rig, pristine to say the least. GLWTS.
zimm
i guess you heard i was looking for one, beefbarley, but you gotta be high as a kite. women must be draining you again. :)
zimm
will entertain offers as well....
i doubt the number you're willing to sell that rig for, and the number i'm willing to pay for a truck i'll hammer like a porn star, actually cross paths. im not a collector. i'll think how far i'm willing to push my number though. youre into '05ish G55 territory.
NoahTheMod
they are split barn doors. hard to see in this picture but you see the metal split in the back.
V45W_Proto2.5
