Just installed a 2" body lift from 4Crawler. My '98 Montero now rides high, and view from inside is awesome. Couple of weeks ago redid the complete front suspension... What a change. Now to look for tires...
Pics please!
What flares are those?
I can detect the leak to be coming from above the alternator. I would assume it would be the front camshaft seal which will need to be replaced with timing belt which is due.
i just did my timing belt and had oil on the alternator and nearby areas, turned out to be the passenger cam seal. valve cover gaskets might be seeping a lil but there was a good amount getting thrown around from that cam seal.well, determined my Monty has an oil leak. Understanding that the 6g72 and 6g74 are know for the rear camshaft leak but they looked fine. I can detect the leak to be coming from above the alternator. I would assume it would be the front camshaft seal which will need to be replaced with timing belt which is due. I have decided to park the Monty until I can take care of that as it goes through 1-2 quarts of oil every 500 miles. I have noticed it doesn't leak nearly as much when not running.
