What did you do to your Mitsubishi today?
cacattack
Thanks Viper! Price was 800.00 installed. 740.00 for the tires and 65.00 to install.
I ordered them from Discount Tire on ebay. Ebay has a promo right now, think it ends tomorrow, where you can save 200.00 off of an 800.00+ set of tires.
I will check your PM. Sorry been away for a week or so...
Thanks
Craig
CJ3B
Thank you! I am thinking painting a red stripe on the wheels in the indentation next to the wheel rim... Feedback?
By the way, that is in direct sunlight. With a bit of shadow or the wheel upright, they look darker and much better... I think that the metallic flake on the finish make it that bright under direct light. Right now they are stored in my garage, and boy, do they look pretty!!! ;)
PacS14
They look good congrats! Which vehicle they come off of? Or is it a particular model wheel? They almost look familiar.
CJ3B
They are a Gen 1 wheelset... they are original Montero wheels, and they are to be installed in my Gen2.
Marutuk
KK6WFB
The main thing I've done recently was fixing a loose wiring issue that caused alternator whine on the radio. (finally!) Next up is doing a full oil change.
bikerjosh
Have the same symptom on mine (whine through the radio), not sure where to start looking?
At1Maverick
uploadfromtaptalk1446502417815.jpgdrained the old gas, gave it a little wash, got it running finally after more than a year.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Atrais
Replaced upper and lower balljoints, inner and outer tie rods ends, idler and pitman arms. And might I say ******** the pitman arm, that thing was a PITA to get off the steering box...
TheMole
Nice how does it drive before/after? OEM parts?
Atrais
Getting it aligned tomorrow (toe is off so it wanders a bit at speed right now) but the steering feel is much improved. There was a large dead spot in the steering between 10 and 2 that is all but gone now. I used all Moog parts but they were all "555" brand and made in Japan. Quality on them looked good, but I did flush the grease that they came with out of the boots when I installed them as I didn't like the look (or feel) of what was in there. Boots themselves looked good and had a decent thickness to them (I couldn't really compare to the OEM ones as they were all trashed) so we'll see how they do.
Atrais
^ Nice truck, I'm on KO2's too. Got mine aligned today: waaaaaaaay better now. Truck feels completely different now (in a good way). Also put in my headlight stalk with the headlight washer button and it works...just doesn't cancel the turn signals automatically. Gonna go back in tomorrow and see if I missed something when I installed it....
