The Woofwagon. Beginning pictures
superbuickguy
If you still have all the EFI stuff from the 350 (and if it's still on the vehicle) - you can easily start the 500 with the 350 gear on it. All we have to do is a quick distributor adapt.... again, I used to run 350s using 4.3 tbis...
superbuickguy
your new friends
http://www.gearhead-efi.com/Fuel-Injection/forumdisplay.php?10-GM-EFI-Systems
the TBI throttle body size is (this is by memory which is faulty at times) is 490 for V6, 570 for SBC, and 670 for BBC. What's important to note is that if it isn't big enough, the truck will fall on its face.... of course, if you have a large enough carb and not enough head flow it would fall on its face too... point is, you won't notice it until at least 3800 to 4000 rpm.... and you will describe it as running out of breath. That means you can start, tune, and run your vehicle as-is and it will run okay. Of course, once you optimize it - that's when the wow factor comes in. Then you'll have the largest TBI body, the larger injectors, custom tune, etc, etc, etc. My point is you can get it on the road with what you already have
Woofwagon
Thanks for the resources! I have already been sourcing some parts such as a TBI to spreadbore manifold adapter and a 454/502 control computer. I did find a complete harness with computer for a 454 that would also control a 4L80E transmission.
Woofwagon
Ok, scored a complete 454 TBI with 4L80E controller on Ebay so in the future I now have the capability of installing a 4L80E for full overdrive with TH400 toughness.
Woofwagon
Mt. Rainier shakedown
Took the Suburbillac up the NW face of Mt. Rainier during a winter storm advisory. Absolutely no snow to speak of. Kind of disappointed but the road to Mowich Lake really needs to be repaved. Shame to see how much they have logged around there, the land now looks so barren.
The Suburbillac worked fine and had opportunity to take the beast through a rather thick mud hole. Chugged right through with no trouble on the 350, the 500 Caddy should have no trouble with any obstructions. The next task for the inside to set up the electrical system for the 'living area' and the on board air compressor with its pneumatic connection to the rear bumper which doubles as a compressed air tank.
chilliwak
Sweet:Wow1:looking `Burb´there Mr Woof. I really like the way that you just drove a few feet off the pavement to get that rig muddy. So cool. I look forward to seeing more of what you do with that capable rig. Thanks for posting. Cheers, Chilli...:)
Woofwagon
Chilli, I don't know if you could call that pavement! It was a heavily cratered cow trail! Looks like it was hit by an airstrike there were so many pot holes.
Woofwagon
+1!
chilliwak
Well we can always call in an airstrike of B17s to aid us...:Wow1::coffeedrink::REOutArchery02::exclaim::violent-smiley-031::yikes::gunt::ar15::ar15::ar15:
oskarf150
