Slow build- the vanagon replacement
6", 35 bfg ko2, major upgrade from the 4", quicker turn ratio, tighter turn radius,more travel and trac bar. If you are debating between 4" or 6" go with the 6". Van is going to be huge either way and the 6" performs all around better and is more nimble.
Mwilliamshs
6", 35 bfg ko2, major upgrade from the 4", quicker turn ratio, tighter turn radius...
I understand the tighter turning radius (traveling in a smaller circle) as a result of being able to turn the tires further before they rub anything (thanks to raised ride height)...
BUT
where'd you get a quicker ratio? Smaller steering wheel or different steering gearbox or a different length (not drop, length) pitman arm?
DanoWall
