99 Jeep XJ Intro and expedition "build" attempt! Plus some restoration.
HercDriver
If you go back to the JY get the crossmember it will have the nutserts. ace hardware has nutserts you can use for the frame side. Leafs will sag more then coils. but its up to you. I would get the v8 steering from that zj. The tie rods are much stronger than the xjs. Great upgrade. the drag links are the same.
Sweet. I may do that. Thanks for the heads up.
HercDriver
Teaser. Cant decide if I want white lettering out or keep it classy with black.
Name:  IMAG2566_zpsbcpy3zmk.jpg Views: 1581 Size:  217.2 KB
Name:  IMAG2565_zpsqdpi2gup.jpg Views: 1353 Size:  215.9 KB
Oh, and the battery died while she sat over 3 days for Thanksgiving.
Had to have my wife jump it. While doing so the o2 sensor ****(crapped) out. The jeep wouldn't idle (rpm bouncing and stank like gas running rich) when warmed up (open loop). Pulled codes and it had P0132 and a few others. Ran to AZ and had em checked out. 02 high voltage or whatever. EDIT: Didn't know EP asterisks out swear words lol.
Had the battery tested out and it tested good. Great, Im going to have to find a draw somewhere.
Anyway instead of buying a battery I walked out with a new o2 sensor and new battery terminals.
Slapped in the new o2 sensor and about a day later the CEL went away and she was running great.
Name:  IMAG2562_zps2tnxriyq.jpg Views: 1328 Size:  172.6 KB
HercDriver
Got some things done over the weekend.
Flushed the coolant. Added some $11 aux lights. Installed ZJ upcountry springs in the front to level out the jeep. Pics below.
I know, the front bumper needs some love. The PO hit a deer and forced everything back together.
Name:  IMAG2627_zpszlzbyd4r.jpg Views: 1394 Size:  251.8 KB
The set of $11 lights. I mounted them to the bottom of the bumper where it attaches to the triangle mount. They definitely help out the weary headlights.
Name:  IMAG2644_zpsehfmdsnw.jpg Views: 1496 Size:  304.4 KB
Heres a pick of the jeep with the ZJ springs. Leveled out the front I think. Works for now until I get a real lift kit.
Name:  IMAG2640_zpszzhxumrt.jpg Views: 1399 Size:  243.0 KB
Preparing for Christmas festivities! Got a cheap ($20) roof carrier from an outlet. Should work to keep stuff dry on the way to see family.
Name:  IMAG2642_zpsn3c9rn6y.jpg Views: 1513 Size:  306.0 KB
Oh, yeah, this happened...
Name:  IMAG2635_zps1ykpvpnn.jpg Views: 1291 Size:  248.2 KB
I had the driveshaft re-tubed and its back in. Ill snag a pic of it later. I still get a little driveline vibes. Ill work on fixing that as well.
HercDriver
It doesn't look like you need anymore lift.
I haven't tested it out (done any real off roading) to see where it rubs/maxes out at. Im sure it will be ok for small backroads or to get to a camp site. I fear I may go off roading and want MORE lift. LOL
mtbxj87
Xjs have pretty good ground clearance at the body stock. The true reason for lift is for larger tires. 99% of time I'm out in rocks I scrape the diffs and that's about it. Im really only at 2-2.5"
HercDriver
Makes sense. When the front had the old xj springs on it, the tires rubbed a small amount on the bumper caps. I trimmed them up to make the clearance. Now that the ZJ springs are in so far they don't scrape :beer:
abctrash
