patoz
Bob, I hadn't updated my thread in over a month and started feeling so guilty I just made a similar post on it myself.
I still don't have a definite solution for Heat/AC yet, so I'll be interested in seeing what you find out about the ProAir System. I still have my evaporator coils and fan, and it can be reinstalled if it will work.
The swing out rack for the spare tire is good because you can mount many other things on there also, including fold down shelves for stoves and cooking, fuel and water cans, etc. I thought about that option for mine also, but I have plans for some other things on the back and that would just be in the way. The tires I have on there now are slightly larger diameter than the original ones, but if the spare will fit between the frame rails in front, I'll mount it just behind the tongue and barely under the front of the body on a winch lowering system like my F250 has. I'll still have to reach under it to drag it out once it's down, but that's not too bad with the aid of a long tool or piece of rope with a hook on it. To get it back under there, I'll just make sure the winch cable is long enough to pull it back under and then up into position.
I wondered about the same thing. In your case you have more and bigger compartments than I do, and a lot more freezing temperatures, so I understand why you're mounting it in a compartment. Two tanks side by side is better as far as center of gravity goes, but one on top of the other is probably better as far as remaining useable space is concerned. In my case, it rarely goes below freezing here, and I have nothing but 12' of free space between the frame rails since I removed the drivetrain and exhaust system, so that is a no brainer for me. All tanks are going there, even if they will be harder to get to for maintenance.Tunneling through water tank catalogs looking for water tanks that will fit in my #1 compartment - the current question is do I install two tanks side by side, or one on top of the other?
