2013 Toyota 4Runner, Equipt Edition Build
Honu
lost on the mainland
look forward to seeing what you do :) as a business of yours I could see doing new builds quite often and moving on !!
again look forward to the next build :)
KlausVanWinkle
It seems like yesterday that I was second in line to buy your 100. I guess I've done 2 builds since then also. My guess is Paul is getting a 200 or a new Tacoma.
p nut
butter
Tacoma is too similar to this 4Runner. The new 200-series just makes too much sense. If I were to get back into a Toyota, it would be a no-brainer.
KlausVanWinkle
True. Also, Paul tends to build his trucks in a very overland-centric-style befitting of the 200's larger footprint and payload. And I'm sure he misses his 100 ;)
happy4runner
Hey Paul, I'll bet you a tasty beverage that its a 2017 Tacoma TRD Pro!
By the way I really enjoyed the party you hosted at the 2015 overland expo!
RedStripeRanger
Water Solution Re-Install
I re-installed the rear roto-pak water solution on top of the composite drawer. This time I mounted it directly to the the surface of the drawer instead of on top of the tie-down rail. Six opposing 3/8" bolts hold it rock solid. No wobble at all this time.
View attachment 229296View attachment 229297
Cheers,
Hi Paul- read most of your build thread (or at least tried to) but did not see where you mentioned what bracket you used for the rotopax? I have been toying with the idea of getting drawers myself, but figuring out where to carry my water inside has been a big speed bump until now. Also, where did you get the 4-gallon water pack? Can't seem to find it anywhere, must be discontinued. Great stuff- sad to see your selling the rig!
Ace Brown
Retired Ol’ Fart
If Rotopax has discontinued that can Expedition One has one nearly identical. Available in white or black.
Equipt
Supporting Sponsor Presenting Sponsor of Overland
Boy, you gotta be quick around here. Ace is right. It is an Expedition One container. I custom built the holder for it. Pretty simple design. And the tap was the result of an Ace Hardware adventure. It has worked perfectly in that space. I don't have to remove the water at every camp, and it keeps gear from falling behind the fridge when I pull it out. I have really enjoyed it.
Cheers,
