locrwln
It was my understanding that the 2wd TB's that I have that are considered the upgrade are "keyed" differently than the 4wd standard TB's.  That is why guys end up swapping sides and going front to back trying to compensate for the difference.
I ended up using the 1500 keys on mine as I did run out of adjustment on the driver's side and it was still not where I wanted it. The 1500 keys gave me back my adjustment and I was able to dial the stock bars in. I didn't try the heavier bars when I had the frontend apart, probably should have. My bumper and winch are heavy and I was hoping that the heavier TB's would help support the weight on those higher speed off-road runs as well as be rated for the additional weight.
I'm done with adjustments up front and it works about as well as the limited travel will allow for. Just not enough travel (compression) for those bigger bumps, but without a complete re-engineer, it is what it is.
Jack
Jack
