toyotech
It's late and I tired. I'll just post one video for now. Rest later
https://vimeo.com/169500481
Find a spring rate calculator and run some numbers before installing more leafs. I should have done that before inadvertently adding hundreds of pounds of spring rate over what I had, I hate doing things twice. If anything I'd maybe run a short block on one side to level it out with the other.
http://www.suspensionmaxx.com/tech-support/leaf-spring-calculator/
This one is good. As accurate as your measurements are.
Are you still running 32" tires? Ever have any clearance issues or wish for larger?
Lots of people who don't need the tire clearance will trim the rear bump stop strike plate to accommodate for more up travel and yet still retain a stock or similar length bumpstop. I was reading a good discussion about it over on TundraSolutions.
Running without bumpstops and new shocks is kind of scary! I would have been paranoid that I would blow the shocks out.
Looks like Moab was a blast!
So with a calculator I can figure out how much spring rate I need to add?
Jose definitely went everywhere... but he did scare me a little bit on the Tip Over Challenge being open/open, haha!
