24HOURSOFNEVADA
I did not do lizard skin on the doghouse. I filled in all the gaps in the factory sound deadening mat then put a layer of dynaliner over that, then replaced the foil faced insulation.
Great, thank you. I also have a question regarding your rear fuel tank cross members. Is it possible to slide them any further forward without the tank hitting the rear end under compression, or the front cross member binding in the upward bend for the rear axle? The reason I'm asking is that I'm curious if your tank will still allow for a rear mounted winch? Is a rear winch one of the considerations of your bumper design?
Top notch work as usual.
