Thought I would share my low budget fridge story and mods. I bought a Koldfront 43 quart fridge last month that didnt work out of the box. After talking to Openboxdirect they weren't interested in fixing it and refunded my money allowing me to dispose of the fridge myself. After some trouble shooting it was discovered the controller was faulty. The Edgestar/Koldfront fridges use a copy of the popular DanFross setup but instead of an all in one controller it uses a separate power supply going to the controller. A friend hooked me up with the DanFross controller that ARB uses for their fridges
http://www.novakool.com/support/documents/ElectronicUnit101N0500Instructions.pdf
And it was plug and play onto the Edgestar compressor including the same mounting bracket on the compressor. This means you can do away with the separate power supply which frees up a lot of room in the compartment and you can also take advantage of the extra features such as power to LED lighting etc if you choose. My fridge now worked but quickly found out the thermostat was not accurate and the fridge would only act as a freezer (KoldFront does not have digital display only a mechanical dial)
After some google searching I found that people with the older Engels have been upgrading to digital temp sensors and there are some kits out there but there are quite a few cheaper options and I ended up going for this one (cheaper options for the same unit but I like Amazons support if there's an issue)
https://www.amazon.com/gp/aw/d/B011VGAPOC/ref=ya_aw_od_pi?ie=UTF8&psc=1
It hooked up easily via 2 wires and there is a small hole plugged by a plastic plug above where the controller sits that I drilled thru into the fridge for the probe. A little silicone and good to go. So far it's working flawlessly and I have it set to turn off at 34 degrees. It will allow temp to climb a few degrees and then cool it back down. You can program it to do what you'd like.
Installed picture
Probe sits in the corner of the upper compartment
I also made up some simple tie down brackets using 11 gauge steel with some small dimple died holes for style points
