Hello all,
I have decided to start a build thread to try and keep better documentation of my truck, relearn some computer skills and share the journey. The build will not be done at a high pace, due to not having a workshop/garage, so updates may be far and few between! What I started with was an 1983 Chevrolet K10. The truck was actually rougher than I thought and I knew it was bad to begin with but I was in a pinch to do some landscaping and haul kayaks for the summer.
May 8th 2014
It needed rear brakes, u-joints, wheel bearings, interior work and leaked plenty of oil but seemed to run good enough and the body was respectable for Canada. In this configuration I was running:
350CI/Turbo 350
NP 208
10 Bolt diffs with 3.08s (rear Posi)
4 inch lift
After sorting out the mechanicals that affected drivability I believe on of the first upgrades was an early 1990's split bench from Pic N Pull!
May 8th 2014
350CI/Turbo 350
NP 208
4 inch lift
